BrokenTrack
- Joined
- Jan 13, 2018
- Messages
- 1,422
- Location
- Maine
- Tractor
- Tractors, Skidders, Bulldozers, Forestry Equipment
People scoff at me because I buy bigger saws and then replace the 20 inch bars with 18 inch ones, but I just let them laugh. To me, cutting wood is getting from point A to point B as fast as I can. With a 18 inch bar, I can cut through a 36 inch tree, and here in Maine, that does not happen very often so I have never wanted more.
There is always a case to build for filing less teeth EVERYTIME, and then the additional cost of 20 inch bars and chains.
But the biggest difference is in LIFTING the saw that extra 2 inches. I noticed it the most while limbing, while going from the bottom of the tree to the top. So one day I did the math, calculating how many times per tree I went from cutting off a limb on the bottom of the tree, to then cutting off a limb at the top of the tree. Adding up the number of trees per day, it became blatantly clear why I was far more tired with a 20 inch bar at the end of the day. It figured out that I was lifting that 14 pound chainsaw some 350 vertical extra feet per day.
That is a lot! That is a lot of extra work for the same amount of pay!!
