3-Point Hitch Hairpin Clip Mystery
   / Hairpin Clip Mystery #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Does anyone know where I can buy this 1/8" hairpin clip?
It is used to retain the stabiliizer bar pin on some Kubota 3 pt hitches.
My dealer claims the parts catalog says "obtain locally". The type he gives me does not have the long leg which makes it much easier to line up with the pin hole. I haven't been able to find then anywhere.
   / Hairpin Clip Mystery #2
Around here most hardware stores have them...look where they keep things like cotter pins and woodruff keys etc.,etc...
   / Hairpin Clip Mystery #4
Agree, the long leg is rather an oddball item.
   / Hairpin Clip Mystery #5
I replaced all my hairpins with simple cotter pins. I mean - really - how often do you remove the lower arms on your 3-point or change the attachment points on your 3-point system.
I remove the stabilizer pins every time I swap 3 pt implements to adjust for variation in width. I gave up on quick hitch systems due to implement compatibility. Some are cat 1, some are cat 2 and the pin width varies. I find the Kubota telescopic drag links are a great alternative. Consequently, I use these pins frequently. Due to their location, they need to be inserted by feel and the long pin extension makes it easier to find the hole.
   / Hairpin Clip Mystery #10
I'm almost sure this was brought up a while ago. Think the guy did find them. Think he even had problems getting them from The dealer. The bottom leg is longer to help it start in the hole easier. I searched around the forum but be darn if I can find it.
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2019 RBR Venturi 380 (A53473)
2019 RBR Venturi...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
