3-Point Hitch Hairpin Clip Mystery
   / Hairpin Clip Mystery #11
I lost one of those from my B2320. I found a pack of assorted pins at either my local TSC or ag. coop and ended up with several pins that worked.
Steve
   / Hairpin Clip Mystery #12
At one time TSC had an assortment with several different sizes in it. Of course that means you'll get a whole lot of sizes you don't need and very few of the ones your do need.
   / Hairpin Clip Mystery #13
I must have lost the hairpin, then the factory pin itself, both very early on. Now each side has a 4" 1/2" bolt, no hairpin(s), nut's or anything, just gravity, and don't you know it the same bolts have over 1000 hours on them never getting lost. 1 side is a grade 8, the other just prolly tsc junk. No difference in wear.:drink:
   / Hairpin Clip Mystery #14
How long is it ?
   / Hairpin Clip Mystery #15
Kubota part #(tc050-5120-0) my dealer stocks them.
   / Hairpin Clip Mystery #17
With my snow blade mounting I have a similar problem.
I solved it by drilling the 'pin hole' oversized and inserted 1/2 bolt and self locking nuts.
I also replaced all the hairpins on my 3 point pins with 1/2" hardware as more than a few times I end up minus the odd one.
LOL, it started off by just having a suitable 1/2" on hand 'just in case' until over time I had replaced all 4.
Naturally when the hairpin falls out you can never find the missing clevis pin either.
   / Hairpin Clip Mystery #19
If you are using them on the stabilizers on the arms then get pins that have spring ball (best way i know to describe them, Lowes here had them) or just use longer pins dropped in there. I have used them this way for years.
   / Hairpin Clip Mystery #20
I too never use the hair pin and for years never had a adjusting pin come out, how can it?
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
40' CONTAINER (A51248)
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
ITEM LOCATION LOT IDENTIFIER 3 (A53084)
ITEM LOCATION LOT...
