Should I buy 45 or 35 H.P.?
   / Should I buy 45 or 35 H.P.? #31
I see you have the 2610 hst.... how do you like it?
Loving it. Fits my needs perfectly. Been flawless but I am only at 47 hours.
I needed to downsize and its the perfect pre Tier 4 option. Ive not needed more so far. It does what I ask it to do.
I downsized from a 60 hp full sized Ford 5040 and a lot of 7 foot stuff. Downsized those implements too to all 5 foot stuff. Needed to do that. Just couldn't horse around on the big stuff anymore. And wasn't farming or haying or such as that. Just some land maintenance and gardening is all. 9 acres myself and tending to an adjoining 10 acres. Just some land clearing/mowing, mulch and gravel spreading and a little garden and food plot tilling. Its perfect for that. 4 wheel drive is nice too.
Recommend it for anyone needing a heavy little pre-tier 4 large landowner/small farm tractor.
   / Should I buy 45 or 35 H.P.? #33
Not sure how hot it gets there, but NX Cab has A/C. CK only has heat. The extra HP on the NX will allow you to run a larger mower for those 15 acres (but, then there's always the CK4010SE as well...). The Kioti snowblower for the NX is 6" wider and 2.5" taller than the one for the CK. I don't know how much area you need to clear, but keep in mind that extra 6" width and the almost 2' larger turning radius of with the NX if it's a tighter area to clear and you need to be more manuevarable.
Edit - N/M... I missed the last page of this thread.
   / Should I buy 45 or 35 H.P.? #34
My tractor stays parked most of the winter and there’s no way I’d have a cab without ac.
   / Should I buy 45 or 35 H.P.? #35
Factory cab on the ck has a/c standard.
The dealer installed cab has heat only.
2015 Nissan Pathfinder SUV (A55758)
2015 Nissan...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55302)
JOHN DEERE ROW...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
Informational Lot - Shipping (A55315)
Informational Lot...
