Should I buy 45 or 35 H.P.?
   / Should I buy 45 or 35 H.P.? #31
I see you have the 2610 hst.... how do you like it?
Loving it. Fits my needs perfectly. Been flawless but I am only at 47 hours.
I needed to downsize and its the perfect pre Tier 4 option. Ive not needed more so far. It does what I ask it to do.
I downsized from a 60 hp full sized Ford 5040 and a lot of 7 foot stuff. Downsized those implements too to all 5 foot stuff. Needed to do that. Just couldn't horse around on the big stuff anymore. And wasn't farming or haying or such as that. Just some land maintenance and gardening is all. 9 acres myself and tending to an adjoining 10 acres. Just some land clearing/mowing, mulch and gravel spreading and a little garden and food plot tilling. Its perfect for that. 4 wheel drive is nice too.
Recommend it for anyone needing a heavy little pre-tier 4 large landowner/small farm tractor.
   / Should I buy 45 or 35 H.P.? #33
Not sure how hot it gets there, but NX Cab has A/C. CK only has heat. The extra HP on the NX will allow you to run a larger mower for those 15 acres (but, then there's always the CK4010SE as well...). The Kioti snowblower for the NX is 6" wider and 2.5" taller than the one for the CK. I don't know how much area you need to clear, but keep in mind that extra 6" width and the almost 2' larger turning radius of with the NX if it's a tighter area to clear and you need to be more manuevarable.
Edit - N/M... I missed the last page of this thread.
   / Should I buy 45 or 35 H.P.? #34
My tractor stays parked most of the winter and there’s no way I’d have a cab without ac.
   / Should I buy 45 or 35 H.P.? #35
Factory cab on the ck has a/c standard.
The dealer installed cab has heat only.
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
