Loader lift capacity and ballast
   / Loader lift capacity and ballast #31
Almost an aside; Consider the load on your front tires and their rating, not just the axle.
For the arithmetic assume the weight of the bucket is out there at about its pivot, typically 4 ft or so and LEVERED on the front tires.
If you are into the "lift all you can and raise the rear tires off the ground" mind set you can assume that ALL the weight of the whole tractor, ballast and load is on those front tires.
Even if you are just a bit short of that think about carrying so much weight on the front TIRES and having one of them blow out.
Just ONE of them, say the one on the down slope.
   / Loader lift capacity and ballast #32
Are you running at full throttle? Are the relief valves set correctly? :confused3:
I adjusted my new loader valve, it was bypassing at 1950 psi, now it's at 2250 psi, so more than 10% greater lift (2250 is what my dealer said it should be at.)
   / Loader lift capacity and ballast #33
Considering it takes near 400 psi just to lift an empty bucket, you added another 20-25% to your lift capacity, not 10 %
PS
You can go another 5-10% on the pressure, (2,400 psi) just make sure you use a gauge and do not exceed the main pump relive pressure.
My loaders more than match the capacity of the tractors.
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2 Drink Cattle Waterer (A50515)
2 Drink Cattle...
