Kubota B2400 PTO does not engage
   / Kubota B2400 PTO does not engage #1
cafsman
Grundy, Illinois
Kubota 2400
Just changed out the HST transmission which was a royal PITA and now neither one of the PTO engages? Did not touch anything on the rear differential and they were both working before. I can depress the clutch fully and the input shaft stops rotating, shift the 540 PTO into "engaged position" and NOTHING. Same with the front 2400 PTO. I am stymied!!!:mad:
   / Kubota B2400 PTO does not engage #2
Do you fix the problem? What was,it?
   / Kubota B2400 PTO does not engage #3
I have a B2100 and just changed out the hydrostatic transmission. Both PTO shafts will not turn also. Did you come up with a solution to fix yours?
   / Kubota B2400 PTO does not engage #4
Almost looks like it may be missing a splined coupler between the HST and PTO input shaft.
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
Test Button (A47477)
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
