Steering wheel broke on my X500
   / Steering wheel broke on my X500 #21
I think you really know how it broke/busted... That would be applying weight or lifting on it when you mounted or dismounted the tractor. My JD 345 and the JD 2320 may have a steel ring/frame in it, for there is no flex or bending whatsoever on the steering wheel. Which make one think that John Deere has cheapen their steering wheels and possible other items on their tractors.
You will probably remove it many pieces when you replace the broken due to it's very thin plastic that is suppose to be a safety feature, as the center (hub) part that is on the steering shaft will need a chisel to remove the hub.
   / Steering wheel broke on my X500 #22
JD likes to save money when they can get away with it.. I'll go with that one..
   / Steering wheel broke on my X500 #23
Looks like it was molded with a gas-assisted injection molding process. It is a way of molding very thick sections while keeping the weight and cost down by injecting pressurized gas to hollow our the center. Allows for faster cycle times and you don't get horrible sink marks like you typically do in very thick sections. I'd chalk it up to a molding defect.
   / Steering wheel broke on my X500 #24
so, how did that miss the steel core?.. it's totally missing on this one!!..
   / Steering wheel broke on my X500 #25
I'm saying it never had one and was designed not to have one
   / Steering wheel broke on my X500 #27
My 33year old 318 has no steel in the steering wheel. Same with my 322.
I would guarantee your la145 has no steel core either.
   / Steering wheel broke on my X500 #28
I'm sure there are people that would ignore the crack, until they get hurt when the second crack appears!..
Maybe everyone should wrap themselves in bubble wrap before attempting to mow their yard, sounds like a pretty dangerous en-devour :)
   / Steering wheel broke on my X500 #29
:laughing: :laughing: :laughing: Sorry, but that was funny.
   / Steering wheel broke on my X500 #30
Just for kicks, today I took a magnet (strong one from a computer hard drive that I dismantled) and checked my gator, 425, 455, and the 4300 steering wheels.. none showed any signs of a steel core.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
