Missouri Lad
Bronze Member
I think you really know how it broke/busted... That would be applying weight or lifting on it when you mounted or dismounted the tractor. My JD 345 and the JD 2320 may have a steel ring/frame in it, for there is no flex or bending whatsoever on the steering wheel. Which make one think that John Deere has cheapen their steering wheels and possible other items on their tractors.
You will probably remove it many pieces when you replace the broken due to it's very thin plastic that is suppose to be a safety feature, as the center (hub) part that is on the steering shaft will need a chisel to remove the hub.
