5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info
I put 70gals in each rear R4 tire & going to put the 350lb wheel weights on as soon as I get the 5/8" bolts.
So around 1,820lbs added to the rear end.
I put 25gals in each front R4 tire & a 187lb front weight plate bracket up front.
So somewhere around 587lbs up front was added.
What I like about fluid filling tires is the excessive weight isn't on the tractors axles or bearings :D
Well, I'm still WAITING on my 4" Wheel Spacers from motorsport-tech.com
I'm DOA until these lands.
4" Spacers came in today :D FINALLY
But They shorted me two 20mm x 1.5 bolts !!!
:banghead:
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #25
we need before and after pics!
Stay Tuned. I'm waiting on bolts from NV to arrive next week.
Nobody around here carries fine threaded 20mm bolts.
My width will be exactly the same as it is now.
I had to flip wheel centers because 350lb weights ONLY fits the domed side of 24" rear rims & width was 4" narrower per side AFTER swapping wheels to opposite sides (wider)
I didn't have enough clearance INSIDE the rims on my current setup to run the 6" Thiick Weights.
I Got the 4" Rear Steel Spacers on, wheel centers flipped (to except weights on outsides), tires / rims swapped sides (v/stems now inside) & 350lb weights bolted on outside of rims
The 4" Spacers with current wheel configuration on the left is the exact same width as config on right w/o Spacers as I had before.
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #28
Good thing you have a loader tractor to put them on. I've hung the 110lb weights by hand and they are a "hand full"
Yea I did the 150lb weights by hand on my two other JD but had helper doing the fastening duties lol
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
1999 John Deere 670CH Articulated Motor Grader (A51691)
1999 John Deere...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
2009 Peterbilt 335 Cab and Chassis Truck (A51692)
2009 Peterbilt 335...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
