Your Land is my Land
   / Your Land is my Land #361
If he doesn't have a survey, how does he really know where the property line is??????? He, the neighbor, and you, can all assume it, but until there's a survey, it's only an assumption. Best to get it legally recorded, then fence it in once and for all and be done with it.
:thumbsup: :thumbsup:
And there is always more than one side to every story...!
   / Your Land is my Land #362
normally without the neighbors permission, a fence has to be 6" off the line.
Not normal here, or anyplace i heard of.
   / Your Land is my Land #363
I kept mine 12" off the line, but it is definitely not a requirement with our township building code. I did it so that if I sprayed herbicides on the fence line there would be no problems with spraying 12 inches outside the fence.
   / Your Land is my Land #364
I have always been told that you want to put the fence about 6" into your property. If you put it exactly on the line, then it belongs to both of you.... [ he has as much right to modify it or tear it down as you do ] Plus you have the problem of digging the post holes. You have to dig on your own property. You do not get to borrow or use land that you do not own. In olden times, farmers would put fences right on the line... but they would usually share the installation and upkeep of said fence as a common property border.
   / Your Land is my Land #365
Also depending on the type of fence you may need to maintain the otherside. If it is right on the line how do you paint/stain it or otherwise maintain it?
We are building electric fence for the horses. We are putting it 10 feet inside the property line. That way we can ride out there and it is two mower widths wide. While the current neighbors are good people I would not want to have to move the fence if they move.
   / Your Land is my Land #366
not here. usually is put right on the property line. I left it off about 3''
   / Your Land is my Land #367
The problem with a fence off the line, is the neighbors think the fence is the line.
   / Your Land is my Land #368
I have been repeatedly told that a fence installed "NOT" on the line,,, becomes the new line after a certain # of years.
Put it on the line,,,
   / Your Land is my Land #369
Make sure that your corners are well documented and put your fence where you want it.
ROME GK-14 LOT IDENTIFIER 118 (A53084)
ROME GK-14 LOT...
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 John Deere 7280R MFWD Tractor (A53472)
2012 John Deere...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
