JD425 Thermostat vs Water Pump ??
   / JD425 Thermostat vs Water Pump ?? #11
Probably thermostat. Need a temp gun. Check your fan blade belt to make sure your fan is turning.
On edit: Harbor Freight has IR guns for about $25.
Sounds like your thermostat is not opening....
I thought the same but you never know, that's why I post on this site, there are those much smarter with mechanical issues that I could ever be. Last year a member helped me trace the wiring on my 790 that was affecting the shut off valve, saved me lots of money and I ordered the replacement module on-line and changed it out myself...… still though, I'm just a rank amateur in this area......
Fan running OK, belt tight but I'll be checking on the "Temp Gun" aspect
Thanks for the Picture, $25 pretty cheap, good to have one around just in case although my wife might say something different :D
   / JD425 Thermostat vs Water Pump ?? #15
"TEMP GUN"...…..That's a new one for me, I'll check to see if I can rent one, Good Advice, now the trick to find one...…..
Harbor Freight puts out 20 & 25 percent off coupons all the time, makes the $25 temp gun $20
   / JD425 Thermostat vs Water Pump ?? #18
isn't the thermostat less than $25? It's a 25 year old tractor. Would be good to change it anyway. Has the CAM ever been changed in that tractor?
2022 Down2Earth 82in x 36ft Two-Car Hauler (A53472)
2022 Down2Earth...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2009 VOLVO VNM DAY CAB (A52576)
2009 VOLVO VNM DAY...
19200 (A50324)
19200 (A50324)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
