JD425 Thermostat vs Water Pump ??
   / JD425 Thermostat vs Water Pump ?? #11
Probably thermostat. Need a temp gun. Check your fan blade belt to make sure your fan is turning.
On edit: Harbor Freight has IR guns for about $25.
Sounds like your thermostat is not opening....
I thought the same but you never know, that's why I post on this site, there are those much smarter with mechanical issues that I could ever be. Last year a member helped me trace the wiring on my 790 that was affecting the shut off valve, saved me lots of money and I ordered the replacement module on-line and changed it out myself...… still though, I'm just a rank amateur in this area......
Fan running OK, belt tight but I'll be checking on the "Temp Gun" aspect
Thanks for the Picture, $25 pretty cheap, good to have one around just in case although my wife might say something different :D
   / JD425 Thermostat vs Water Pump ?? #15
"TEMP GUN"...…..That's a new one for me, I'll check to see if I can rent one, Good Advice, now the trick to find one...…..
Harbor Freight puts out 20 & 25 percent off coupons all the time, makes the $25 temp gun $20
   / JD425 Thermostat vs Water Pump ?? #18
isn't the thermostat less than $25? It's a 25 year old tractor. Would be good to change it anyway. Has the CAM ever been changed in that tractor?
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
434669 (A48836)
434669 (A48836)
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
