FORD 1920 3pt TILT CYLINDER AVAILABLE ?
   / FORD 1920 3pt TILT CYLINDER AVAILABLE ? #1
fried1765
Super Star Member
Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I would like to add a tilt function to my ford 1920 3pt hitch,
What cylinder should I use (approx. 16" retracted x 24" extended)?
Is there a direct fit available (with proper ends)?
What would be a suitable 2 spool valve (might add top function later).
Functionality is primary, but overall cost is also a consideration.
   / FORD 1920 3pt TILT CYLINDER AVAILABLE ? #2
Not sure that's there's any off the shelf.
A 2-2.5 x 6-8in cylinder should work, 2.5x8 would be good if you can get it to fit.
Any valve with at least 8gpm rating, open center with power beyond capability will work.
For the money I've had good luck with Prince Wolverine serues valves.
If you want to buy them then Mtnviewranch on here can make them, just might take a little while as he's usually backed up with orders it seems.
Thanks!
I just remembered that "Fit Rite" makes custom tilt kits. I sent an e-mail requesting information
   / FORD 1920 3pt TILT CYLINDER AVAILABLE ? #4
Thanks!
Not fast, but good work & he stands behind his gear.
These folks show a few. TOP-N-TILT
Thank you for the link.
Unfortunately all those listed are Top Link, and the piston stroke is too long for my side link application.
I need it to be a 6" stroke, between 13" and 19" to work with my Ford 1920 3pt.
I really do not need a top link, as I already have a "Hydraulink" (poor man's manual hyd. top link).
I want the hyd. side link (tilt) to use with my brand new ETA Deluxe 6 way scrape blade (beautifully built piece of equipment).
I found a new 1.5" x 6" cyl. ($63) from an E-Bay seller, with 6" stroke, that should work perfectly, after I modify the end attach points.
I calculate that the 1.5" dia. cyl. will provide plenty of force to do the job, while not being as bulky as a 2" or 2-1/2" dia. cyl..
Will use a Prince Wolverine 2 spool 8GPM valve (E-Bay $147), plus hoses/fittings etc., and all should be good.
Fit Rite would likely be somewhat more sophisticated, but far too rich $ for me, and a 29 year old tractor.
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
New Holland B95 Backhoe (A50490)
New Holland B95...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
