Brush cutter size for a given horsepower
   / Brush cutter size for a given horsepower #21
Would I be able to RUN A Bush Hog 2610 with a 1963 John Deere 4010 diesel?
The mower says 1000 PTO. Is that something to stay away from? I'm not familiar with that/ Just 540.
   / Brush cutter size for a given horsepower #22
if it is a 1000 rpm mower, you need a tractor that does 1000 rpm on the pto. generally 1000 rpm pto's are small/old and asian or large like arounf the 100+ hp range. There are exceptions in the domestic antique market as well.
   / Brush cutter size for a given horsepower #23
I was thinking the 1963 John Deere 4010 had something where you could easily change the 540 to a different RPM. I'm not sure what that RPM was or if I even have a clue what I am thinking of. According to this you can swap from 540 to 1000 - If I am getting that right. Next I will have to search how to do that.
With the 1000 PTO, would this tractor have enough hp to run the 10' batwing?
TractorData.com John Deere 4:) tractor information
   / Brush cutter size for a given horsepower #24
10' should be no problem at all for a 80hp 4010
What RPM the pto is dont matter in terms of HP
   / Brush cutter size for a given horsepower #25
What RPM the pto is don't matter in terms of HP
Are there any huge disadvantages to running a 1000 RPM Mower?
I can imagine that 1000 RPM might be harder on things than a 540.
The spare PTO shaft that came with the tractor - that I assume is for the 1000 RPM swap - looks like it might need to be cleaned up a bit. It looks like it's been sitting in the tool box for 40 years or so
   / Brush cutter size for a given horsepower #26
Parts might be harder to find and PTO shaft balance will be more important, it will lock you into finding a 1000 RPM capable tractor if you need to replace your tractor down the road.
Otherwise, it should work fine.
Aaron Z
   / Brush cutter size for a given horsepower #27
The blades will only be turning at 54% of their designed speed.
It will be like running a 540 rpm mower at 291 rpm.
Will it still cut? Depends on what your cutting and how fast you're going.
I believe (someone check my math) if you drive at 54% of your normal speed, the torque required will be equal to a 540 rpm mower, but you'll only need 54% of the horsepower.
and if you drive at normal speed, the horsepower required will be equal to a 540 rpm mower, but you'll need (1/.54=) 185% more torque (assuming the blades are going fast enough to cut).
   / Brush cutter size for a given horsepower #28
When I bought my JD the dealer said you want the bush hog = to or a little less than tractor width. That way you can cut along a fence line easily. I wanted all the hp I could get for the size, rather too much than too little.
   / Brush cutter size for a given horsepower #29
Your 4010 will handle a 10 footer well. I run one with 65 PTO HP and you have more HP at 80 or so. Since your Deere has 540/1000 PTO available looks like a good fit to me. I typically run 5.8 MPH according to my dash panel. That is 2nd range in 4th gear. I could run it in 3rd range and 1st gear but it is too fast to my liking.
   / Brush cutter size for a given horsepower #30
Thanks. I am going to an auction tomorrow. Have to see what that mower sells for.
Itr is a one wing mower. I still do not know if you could just run the 5" section without some major disassembly. 10' would be good for the road ditches and CRP.
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A54865)
IMPORTANT PLEASE...
