Brush cutter size for a given horsepower
   / Brush cutter size for a given horsepower #31
The blades will only be turning at 54% of their designed speed.
It will be like running a 540 rpm mower at 291 rpm.
Will it still cut? Depends on what your cutting and how fast you're going.
I believe (someone check my math) if you drive at 54% of your normal speed, the torque required will be equal to a 540 rpm mower, but you'll only need 54% of the horsepower.
and if you drive at normal speed, the horsepower required will be equal to a 540 rpm mower, but you'll need (1/.54=) 185% more torque (assuming the blades are going fast enough to cut).
I think the OP is talking about running a 1000RPM mower on a tractor that has a 1000RPM PTO, not running a 1000RPM mower on a 540RPM PTO.
Aaron Z
   / Brush cutter size for a given horsepower #32
Aaron Z
Correct. Check the 4010 link from the earlier post
   / Brush cutter size for a given horsepower #33
There is not appreciable difference in 540 pto on a 540 mower and 1000 pto on a 1000 tractor.
Torque is what breaks things. Changing speed and gearing doesnt change HP but it certainly does change the torque.
Pushing 80HP through a 540RPM shaft takes almost twice the torque as it does to push that 80HP through a 1000 shaft.
Since things can only be built so strong within a reasonable weight to be able to handle hooking up and unhooking....onces tractors started pushing 100 HP and beyoned....the need to increase the PTO speed to transmit that torque through a reasonable sized shaft became a necessity.
Newer stuff of even higher HP maintained the 1000rpm, but upped the shaft size to 1-3/4
   / Brush cutter size for a given horsepower #34
Thank you much.
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
2016 BOBCAT E45 EXCAVATOR (A52706)
2016 BOBCAT E45...
2019 FREIGHTLINER CASCADIA SLEEPER (A56129)
2019 FREIGHTLINER...
