MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 57,934
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
We've got a 2-person tent, a 4 person tent, and a three room tent, all nylon, all were under a hundred bucks. All are 25 years old and all are still in good condition.... with the exception of the bungee cords in the pole sections. All of them have degraded over time and broken, like the old elastic in your holy underwear. They'd be easy enough to replace though. The 2 and 4 person tents are what I'd consider 3 season tents. I don't think they'd hold a snow load very well. The 3 room tent is large enough for two queen sized air mattresses, one in each of the side rooms, and two chairs and a table in the center room. It is more of a summer tent, as it has screen over the center room. All of them have rain flies. They've all been used dozens of times.
I think you could get a very acceptable 3 season tent for around $199 or less. Depends if you want to stand up in it or not. I'd spend some money and get a better quality air mattress and a 12v inflator. THAT's what'll make you all comfy at night. :thumbsup: :thumbsup: Sleeping on the ground, or a pad, or a cot is just not nearly as comfy as sleeping on a good quality air mattress. We've got a king and a queen. My daughter has a queen. We sleep on them when we visit her and vice versa. I like it better than most hotel mattresses, it's that comfy.
A wood floor is nice to put a tent over for sure, as it keeps the tent off the ground, water will go under the tent, etc..., but it's not necessary. Get some 1.5 or 2" PVC pipe and make a simple frame the same shape as your tent floor, but a tad smaller all the way around. Lay the frame on the ground, lay a waterproof tarp or plastic over the frame and tuck it well under the PVC. Then set your tent up over the frame so that your sidewalls hang over the PVC frame. Any groundwater that runs toward the tent will hit the frame and run around the tent, not under it. Drop in your air mattress and you're good.
Another thing that's nice to have is a stand for a backpack, so the backpack hangs on it upright and you can use it like a dresser. It also keeps it off the floor and takes up less floor space than laying it down. Make some racks out of conduit and use bolts and wingnuts to hold things together in open or closed position.
There's a ton of cheap, LED battery powered lamps out there, but I'd go for some 12v rope light or LED's. A good deep cycle marine battery, a solar charger panel, and you're good to go.
