Ford 1715 rear wheel
   / Ford 1715 rear wheel #1
Dataway
Gold Member
Greenfield TN
Ford 1715, BX2200
Is there a source for aftermarket rear wheels for the 1715? OEM is about $1,000. It uses the 6 lug, wheel that fits a 11.2 x 24 tire ... although the rim itself might be a 10 x 24.
I have a feeling it might be rusted badly on the inside ... judging from the outside appearance.
Would be happy to use any wheel as long as it fits the 11.2 x 24 tires that I have, and bolts to the tractor.
Resurrecting this question ... still think I'm going to need a rear rim. Any sources for aftermarket rear wheels for a 1715. It's got the one piece on it now, but I'm open to whatever will fit and roll. Thanks
I need the rear wheel for an AG tire ... rim is 10 x 24 and the tire I think is 11.2 x 24.
   / Ford 1715 rear wheel #5
Weaver Compact tractor in PA. Bought used turf wheels for my 1620, one year ago. Sould have used AG tire wheels also.
Creamer, sequence of tractor series as I know it.
1700, then 1710, then 1720. The 1715 was produced while the 1720 was still in production. Not sure about 1725?
   / Ford 1715 rear wheel #6
I know this is off subject but can somebody explain why Tractor data shows the 1720 from 1987-2000 and the 1715 from 1992-1997. Did it go from 1710 to 1720 to 1725 and the 1720 was built from 1987-1991?
Models like the 1715 were budget models built concurrently with other models.
That would be excellent ... except I have the one piece rear wheels. I'd be willing to replace center section and all rather than pay $1000 for a factory wheel. Haven't ever seen the center section for sale aftermarket either.
Wonder if you can run one loop style wheel and one single piece wheel.
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52128)
Adams Load Out...
BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
BOMAG BW172D-2...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2025 CFG Industrial JDCPF48-4400-FF Pallet Fork and Frame Attachment (A49462)
2025 CFG...
