5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #31
How many 110lb weights are you running per side ?
Two, I had a 2030 gas about 25 years ago. I soon sold it, used too much fuel, and kept the weights. They stack with 5/8" carriage bolts, one weight to the next.
I've been watching for more, but either too far away or sold when I call.
Every time I Bush Hog my Big Steep 700ft long bank : I'm truly amazed with the added weight getting superb traction in 4wd backing up & driving down with 10ft 2300lb 3pt hitch lift type MX10 Cutter :D
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #33
Sometimes bigger is better! I do love my MX10!
Is yours a semi mount, pull type or 3pt lift type ?
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #35
Full 3pt Mount
:thumbsup: only way to go for my application cutting Steep banks
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #37
Absolutely, I would hate to try and back down a hill steering a tow behind cutter and worrying about jacking knifing. I like the quick turns in the corners and being able to swing the mower around objects. I do wish it was easier to mow against fence lines without worrying about sliding into them but I'll take that.
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #38
That's where the hydraulic offset would be handy. I do not have smooth enough ground for a fixed 10', I would need a flex, like a one wing batwing, BUT so not want a pull type, I do to too much backing. I also mainly mow trails, so I have a 6' and considered an 8'
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #39
I do think the hydraulic offset would be nice, I really wish I had something to mow under the fences, but for the wide open pastures I do like the extra coverage outside the tires. If I mowed any more acres I certainly would look at a 15' batwing or so. I think my tractor is JUST big enough for the 10 footer and sometimes a little bit more wheelbase would be nice but, I sure wouldn't want anything any bigger out back. Surely you don't pull a 6 footer behind the 6415??
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #40
No, 2030 does the mowing.
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
More info coming soon! (A50323)
More info coming...
2019 John Deere HPX815E (A50123)
2019 John Deere...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
1992 Ford E350 Box Truck (A53117)
1992 Ford E350 Box...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
