Hydraulic Top Link for Mahindra Max26L
   / Hydraulic Top Link for Mahindra Max26L #1
GirlWhoWantsTractor
The Mountains of Virginia
2018 Mahindra 26XL HST, Husqv GT48XLsi & YTH48LS
Can anyone point me in the right direction? If I order the parts (preferably a kit), I can have the dealer install it when it goes in for 50-hour service. I really don't want to wait weeks for a Fit-Rite.
   / Hydraulic Top Link for Mahindra Max26L #2
Your dealer should be able to get a kit through Gearmore or whatever the name of that wholesaler in your region is called.
If I’m spending your money you might as well get a side link as well.
That sounds easy, and I like easy. Thanks.
I think there is an option for only one rear remote?
The main thing I need to tilt is the rear blade, so I got a tilt-blade.
   / Hydraulic Top Link for Mahindra Max26L #5
Btw- if you do just go the top link route I thought they made a device that you could just reach back from the seat and adjust without booking into existing hydros and without getting off the machine- I’ll try to find it on YT
That would be fantastic, thank you.
And thank you for the link, RNeumann.
Is the shock absorbing function an extra benefit vs a regular 3rd function setup?
   / Hydraulic Top Link for Mahindra Max26L #10
This??
HydrauLink Category 1 Cylinder - For 45 HP Tractors or Less, Model# HL-11 - YouTube
OMG that looks fantastic! Is anybody else using one?
And only $219.00
I'm assuming it would be compatible with a QH?
I have two of the Hydraulink units, but bought the CAT II model for my CAT I tractor use. I bushed them down to fit the 3/4"" CAT I top link ends.
I determined that I needed the longer reach of the CAT II units (24-5/8" - 28-5/8") because I am also using the Pat's Easy Change hitch.
Not as versatile as a real hydraulic top link, has a bit of a learning curve, but is very cost effective.
For my use, a real hydraulic side link is much more important.
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
