jrsavoie
- Joined
- Jul 10, 2010
- Messages
- 511
- Location
- Clifton, Illinois
- Tractor
- 1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
The diesel issue I was thinking of would be growing a microbe garden in the fuel tank.
As far as a road trip to go shopping;
I have a 1/2 ton, and the heavy trailer I could borrow, I wouldn't trust going hundreds of miles.
If you would post your location, people would help you shop. Everybody loves to spend other people's money!
A neighbor that helped me install a Schwartz loader on my first 1963 4010 - about 34 years ago - was telling me back then that the widen fronts for the 4010's and 4020's were a weak spot when used with loaders.
He said at the time, if I thought I was going to use the loader I installed to it's potential, I would want a beefier front on the tractor - and the side rail stiffener kit.
At the time he had all the info on swapping the wide fronts. I do not remember if it was an aftermarket kit he was talking about or some other kind of swap. He was a wealth of information and left us way to soon.
Maybe google something like heavier wide front under John Deere 4010 - or other tractors - for a loader.
I use additives to avoid the microbe garden issue.
In general, I have had far fewer issues with diesels than gassers.
Says the guy who's 1975 Ford backhoe is currently laid up because the Injection Pump is leaking around the throttle shaft. Even that is not serious. $8 in parts and a few hours labor
yOU CAN FIND SOME NARROW FRONTS REALLY CHEAP. If you research what it takes to swap to a wide front, you might be able to get something pretty reasonably
For a 4010
