Hay Making Equipment: What Size Tractor?
   / Hay Making Equipment: What Size Tractor? #1
MountainMomma
None yet
Hi,
We have been reviving a small (40 acre) farm in mountainous WV for the past 7 years. We bought a 1956 Ford tractor that we have nursed along until now, but it is slowly dying.
We have decided it would be a good thing overall to upgrade our tractor with an eye towards haying 20 of our acres in the future to feed our two horses and sell the surplus. We are thinking square bales, because there is a market here for them among horse people, and they are easier for us to handle.
Question: does anyone have a link to an overview article that would tell me about the process and needed equipment for a SMALL hay making set up? Also, does anyone make hay would would be willing to advise us? We are thinking we want to buy used equipment, but we are not handy. Small is beautiful here: we aren稚 bells-and-whistles types! We just want to make up about 20 acres a year in order to keep our land in pasture.
Any help will be VASTLY appreciated. I don’t know even the categories to compare tractors: does one use hp or other criteria to match with haying cutters and bailers? Help, please! TIA
   / Hay Making Equipment: What Size Tractor? #2
My dad hayed about 30 acres a year with a 45hp tractor, sickle bar mower, grim ground driven teddar, an old Deere rake and a Deere 14T baler for many years. if you have the money I would suggest a New Holland baler, either way, you’re going to need some wrenching skills, a baler is all about timing, the knives and knotters have to be in time or there will be problems.
My brother bales 20,000 squares a year, he knows his equipment like the back of his hand. It takes years to learn.
   / Hay Making Equipment: What Size Tractor? #3
I cut, rake and square ale about 15 acres and sell the hay to local horse owners. A few buyers have been with me for over 20 years. I use a JD 1070 geared tractor (35 hp) which has a detachable loader. This gives me hydraulic options on my hay mower (a late '60 NH 479 9' mower, and my NH 1012 stack wagon used for picking up the bales dropped off by the baler (which is an old JD-14T unit that still makes wonderful bales) I use a NH 55 rake and occasionally a Kuhn Tedder/rake combo unit.
I have hills in the back that are pretty steep but no stability problems. All the hay equipment pad for itslef in 2 years. (Farm 1099 as a business). I would only recommend getting cheap old equippment if you are mechanically inclined. But, most spare parts (belts, rake teeth, mower blades, tires, hydraulic stuff comes from TSC or Rural King.
Its a lot of fun, but hard work if the weather is hot and humid. Your horses will benefir from a consistent hay supply with potential use as feed for boarders if you have the inclination.
Here's a few previous season videos I've posted on Youtube:
Hay Baling 214 - YouTube
2:censored:813 2411 - YouTube
I'd be happy to give free advice, as long as you are not asking using facebook.
   / Hay Making Equipment: What Size Tractor? #4
We also used a JD 1070 compact tractor with loader and had a set of hoses made up to run remotes off the loader controls. New Holland 489 haybine worked it hard but it worked for 20 years, New Holland square baler bought used and had implement dealer go through it each season. Originally had new Holland 256 rake but towards the end bought a Tonutti 8 wheel rake. Benefit of the 256 has front dolly wheel so it could be pulled by ATV in a pinch...8 wheel rake needs hydraulics but cuts raking in half and can be adjusted to make perfect width windrows for the baler. 35 hp is marginal to run equipment, would suggest 40+ hp with at least one rear remote for hydraulics.
My dad hayed about 30 acres a year with a 45hp tractor, sickle bar mower, grim ground driven teddar, an old Deere rake and a Deere 14T baler for many years. if you have the money I would suggest a New Holland baler, either way, youæ±*e going to need some wrenching skills, a baler is all about timing, the knives and knotters have to be in time or there will be problems.
Okay... so, there are several Deeres for sale on CL in my area. Is 45 hp better than 35 hp, or will it require bigger attachments all along the line?
Also, what is a reasonable ballpark number on hours (the odometer of tractors, as I see it) on a used tractor? (I know there must be nuances, like what kind of hours; how well maintained, etc. but give me a ballpark, please?)
How would a JD 1020 work on hills? With haying equipment. Seem to be a lot of those in my area...?
   / Hay Making Equipment: What Size Tractor? #8
More HP is always better when your talking haying equipment. 40-50HP is plenty for small a haying operation. A loader will be very important as well. If the tractor is diesel I would say 3000-4000 hours would be okay if it's good shape. You could certainly use a gas tractor as well but the hours should be maybe a 1000 lower than a diesel, They will both get the job done.
My brother uses a Ford 7710 with 8000 hours on it and it works great. If you decide some day to use a baler with a kicker and kick bales into a wagon so you don't have to pick them up off the field you will need a heavy tractor to do. But if your planning on picking them off the field I would at least suggest a hay drag, when the bale comes off the baler they will fall into the drag, when there are 8 or so bales in the drag the rear door releases and drops the 8 or so in one spot..
214813 2411 - YouTube
Thank you so much! I will keep you in mind. If we buy newer (not new) equipment, how hard is it all to maintain? We are not mechanically gifted!
   / Hay Making Equipment: What Size Tractor? #10
hello!!! while I cannot remember the exact baler model numbers or tractor model numbers, EVERY square baler and round baler people I worked for bucking hay growing up had little fords - I don't think any of them had more than 35hp - lower center of gravity but I would NOT recommend them on hilly ground. They had terrible brakes and would push the tractors when going down hill because they were too light for the baler or a wagon load of hay.
I put up between 20 and 30K bales each summer for mostly sheep/cattle/horse people back in the 70s/80s - had a few small allis round balers and they were awful........no worries those are long gone. most all were deere and new Holland, I think a model 22 or 24 deere was one of them cant remember the numbers on the new hollands
If you are using older equipment and can find something in the 40 to 50 hp id say it would be better for a tractor if hilly due to the size/weight - if you are going to look for newer stuff maybe in all wheel drive on the hills would be the best, and you could go lower hp/weight - just remember you can cut/rake/bale on a side hill to help deal with the slopes but when hauling if you stack very high you will have to go up/down those hills - im sure you have the hang of that already at this point -
do you all have a budget you want to stay in that would help a little trying to figure out a tractor/baler - I think the 30 series deere would be adequate as well as the farmall 400/450/560/656 all could be had for fair $$ as well as reliable and size/power appropriate - had good luck with allis D17s - 4000/5000 series fords would be good - my uncle had a 4600/5600 and they were dandy runners - lots to choose from in your hp/size range, I would try to find something 4500lbs and above if you have hills just my thoughts I am sure some of you will have much better info -
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
2007 Capacity TJ6500T Trailer Jockey Truck (A55973)
2007 Capacity...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
