Sprinkler driving me crazy - valve won't open
   / Sprinkler driving me crazy - valve won't open
Ah. Good job of narrowing it down. Swap out the head on the one that doesn't work with a known good one, if you haven't already, to eliminate that head. While it's off, run the water and see if water is getting to that point.
Also, before digging anything up, I'd cut the line just past the valve, and put a gallo gun into the line, remove all the head sprinkler heads, and give the gallo gun a couple-three shots down the line. Then glue on a hose fitting at the cut and run the water to see if that clears it out.
If you don't know what a gallo gun is, here's a link. It's a co2 powered drain line blaster. We use them a lot at my employer to clear drain lines, condensate drains, etc.... works great! Worth a shot.
Amazon.com: DiversiTech GG-1 Charles Gallo Drain Gun for A/C Condensate Lines: Industrial & Scientific
That is a pretty cool gizmo. I'm pretty sure that the pipe is cut and capped or crushed. Being one inch PVC, I just can't see it being plugged with debris so thoroughly.
   / Sprinkler driving me crazy - valve won't open #22
Yeah, most likely. Especially since your back feed test showed all but the first head working, it's blocked somewhere between the 1st and 2nd head.
Yep and that is most likely under the paver covered garage apron. That would be a mess to try to dig up.
   / Sprinkler driving me crazy - valve won't open #24
Sounds like a good excuse to purchase a backhoe, ripper tooth, cement mixer, dump trailer, etc... :D
   / Sprinkler driving me crazy - valve won't open #25
It turns out that my stuck valve was stuck, but that was only step one. The line is capped somewhere between the valve and the first sprinkler - under a foot of hard decomposed-granite-based soil. My HF rotohammer is going to get a workout. Another valve in the same box seeped, so I replaced it's parts. That cured that issue.
I feel your pain. :laughing:
   / Sprinkler driving me crazy - valve won't open #27
My best guess was a capped line... been there before.
Good sleuthing on your part.
   / Sprinkler driving me crazy - valve won't open #28
If it's capped between the valve and the first sprinkler, why didn't the first sprinkler get water when you back-fed it?
Broken/capped in two places?
   / Sprinkler driving me crazy - valve won't open #29
That was the OP, not me.
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
20' 1 Trip Shipping Container (A59814)
20' 1 Trip...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2007 MACK CV713 ELITE DUMP TRUCK (A60430)
2007 MACK CV713...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
207275 (A52708)
207275 (A52708)
