SHUTTLE SHIFT, REDUCE POWER first?
   / SHUTTLE SHIFT, REDUCE POWER first?
ABSOLUTELY! That's my main use for my 4310, a loader tractor. It has the powerReverser 12X12 trans. I only touch the clutch once when i start it; everything else is done with the foot throttle and shuttle. I usually give it 1 second in neutral when switching directions. Hope this helps!
Oh so you use footpedal but no clutch when using the shuttle valve? I guess I was doing the opposite..:laughing:
edit: just looked it up in the mf1240 operator manual. It states to reduce engine rpm AND press the clutch.
   / SHUTTLE SHIFT, REDUCE POWER first? #12
Easy now, his description of useage is deceiving.
   / SHUTTLE SHIFT, REDUCE POWER first? #13
Well, I suppose you should follow the manual. Do you have a fully synchronized trans? Do you have to bring the tractor to a stop to shift?
edit: I just looked up your mf1240 & my jd4310....dry disc vs wet. that's why you need to clutch to shift the shuttle. I would drive it like the old dump truck... alternating feet you're either on the clutch or the foot throttle. make sense?
   / SHUTTLE SHIFT, REDUCE POWER first? #14
I tend to hesitate just a moment before utilizing the shuttle. I hardly ever run at higher RPM's unless I am bush hogging. I run at the rated RPM. Typically I run around 1500 to 1800 RPM's. With the hydraulic shuttle I do not depress the clutch.
   / SHUTTLE SHIFT, REDUCE POWER first? #15
So when I am moving dirtpiles, is it easier to use the footpedal ?
Thanks for the comments.
Much easier for the operator and clutch IMO.
I always use my foot throttle to throttle up/down for forward/reversing for loader work, mowing, brush mowing, ETc. Etc.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
UNUSED RAYTREE RMSG29 29" HYD STUMP GRINDER (A57193)
UNUSED RAYTREE...
2008 Freightliner B2 School Bus (A55852)
2008 Freightliner...
BLUEBERRY MIDDLE BUSTER (A57192)
BLUEBERRY MIDDLE...
DIRT DOG BBX72 72" BOX BLADE (A57192)
DIRT DOG BBX72 72"...
2007 Anderson 25ft 7 Ton T/A Flatbed Equipment Trailer (A55852)
2007 Anderson 25ft...
