SHUTTLE SHIFT, REDUCE POWER first?
   / SHUTTLE SHIFT, REDUCE POWER first?
ABSOLUTELY! That's my main use for my 4310, a loader tractor. It has the powerReverser 12X12 trans. I only touch the clutch once when i start it; everything else is done with the foot throttle and shuttle. I usually give it 1 second in neutral when switching directions. Hope this helps!
Oh so you use footpedal but no clutch when using the shuttle valve? I guess I was doing the opposite..:laughing:
edit: just looked it up in the mf1240 operator manual. It states to reduce engine rpm AND press the clutch.
   / SHUTTLE SHIFT, REDUCE POWER first? #12
Easy now, his description of useage is deceiving.
   / SHUTTLE SHIFT, REDUCE POWER first? #13
Well, I suppose you should follow the manual. Do you have a fully synchronized trans? Do you have to bring the tractor to a stop to shift?
edit: I just looked up your mf1240 & my jd4310....dry disc vs wet. that's why you need to clutch to shift the shuttle. I would drive it like the old dump truck... alternating feet you're either on the clutch or the foot throttle. make sense?
   / SHUTTLE SHIFT, REDUCE POWER first? #14
I tend to hesitate just a moment before utilizing the shuttle. I hardly ever run at higher RPM's unless I am bush hogging. I run at the rated RPM. Typically I run around 1500 to 1800 RPM's. With the hydraulic shuttle I do not depress the clutch.
   / SHUTTLE SHIFT, REDUCE POWER first? #15
So when I am moving dirtpiles, is it easier to use the footpedal ?
Thanks for the comments.
Much easier for the operator and clutch IMO.
I always use my foot throttle to throttle up/down for forward/reversing for loader work, mowing, brush mowing, ETc. Etc.
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A55852)
2022 Chevrolet...
2017 Ford F-750 Super Duty (A53317)
2017 Ford F-750...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
CATERPILLAR HYD HAMMER (A52707)
CATERPILLAR HYD...
2019 John Deere 550K Crawler Tractor Dozer (A55851)
2019 John Deere...
