What are these called and where do you buy them?
   / What are these called and where do you buy them? #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
We called them "tub skids" back in the early 80's up in Boeing Seattle. I have no idea what they're real name is.
But I need one (or more). Approximate size is 4'x4'x3' or so.
So what are they called, where can I buy one (or more) and typically how much do they cost?
Thanks!!
   / What are these called and where do you buy them? #3
Watch for them at industrial auctions. Problem is, they often are sold in industrial sized lots.
   / What are these called and where do you buy them? #4
Or scrap yards in cities with a decent manufacturing sector.
   / What are these called and where do you buy them? #5
Every scrap yard I’ve ever been to is littered with them but won’t sell them at least for a fair price because they use them.
   / What are these called and where do you buy them? #6
I worked for a company that got raw plastic pellets in tubs that size only the tubs were heavy duty multi-layer cardboard. In the injection molding industry they were called - gaylords.
Each cardboard gaylord would hold a ton of plastic pellets. We only got special and exotic types of plastic in these small lot sizes. Normally our bulk plastic came in a rail car and it held around 65,000 pounds of plastic pellets.
   / What are these called and where do you buy them? #10
Some of those tubs are ' drop bottom ' and the bottom opens up when the tub is put in the proper stand made to let it open up. The standard tubs are usually dumped by using a fork truck with a rotating set of forks to turn it upside down. There used to be big piles of them out in the parking lots at GM machining plants. They are common industry tubs.
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
