Tacky film on fan blades
   / Tacky film on fan blades #1
TomIre
Gold Member
College Grove, TN
Branson 3725
Did the 50 Hour Service on my 3725 and found something on the back of my fan blades. Not oily but more like tacky. A little bit was slung around the engine bay too. I cleaned it off and will keep an eye on it. Any idea what it could be it or where it can be coming from?
   / Tacky film on fan blades #2
Antifreeze can be a bit tacky when it drys.
   / Tacky film on fan blades #4
Mine is the same. Most likely bugs and vegetation residue.
Thought it could be bugs, etc as I do a bit of bush hogging. But, it's on the back side of the blades. Closest to the engine and "down wind" so to speak.
   / Tacky film on fan blades #7
That's the side that does the work. It's just bug juice mixed with a little dust & seed chaff.
   / Tacky film on fan blades #8
In one of the fields I mow with my riding lawn mower - the back side has quite a stand of milk weeds. Now - you want to talk about something that gets sticky. Just mow down a big patch of milk weed and let the sap dry.
   / Tacky film on fan blades #9
Yep. I usually wipe if off the blades and underhood body work after cutting season. I use window cleaner but I'm sure others would work fine.
   / Tacky film on fan blades #10
You can add Dallis grass seeds to that. Stick like a magnet to iron and easily stuck.
2009 Wells Cargo 5th Wheel Office Trailer (A53117)
2009 Wells Cargo...
2016 HAMM HD+ 120i SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120i...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
