Kubota f 3680 intermittent hst drive failure
   / Kubota f 3680 intermittent hst drive failure #1
kubota Karl
aurora
kubota bx25d
I have a 2012 kubota f3680 that works well but more than a few times near the endd of cutting lawn the hst lags or is very slow in reverse or forward and i hear it squeeling. Going down hill it may lose all controll for a second or two. Hydraulic hose was leaking a tiny bit but tightened it and has stopped. Fluid level always seems i indicate it is full. Also i note that i have to raise rpm to lift the cutting deck. Any help i am pretty sure I am not competent to take tansmission apart or anything like that. Help
   / Kubota f 3680 intermittent hst drive failure #2
How long ago did it get a hydraulic oil and filter change? Suction hose leak also a possibility?
I took it in last year thinking it was the peddle mechanism itself and they repaired it and said hydraulic pressures etc were fine
I don’t believe that they changed the oil or filter, many times it will seem to work perfectly but at the end of the 2 acre cut it seems to happen. When it was leaking why was the oil not going down?
   / Kubota f 3680 intermittent hst drive failure #5
But what about the oil filter and screen
  • f3680.pdf
  • F36802.pdf
I have no idea about that, I bought it used and no manual to find the screen. I guess i will take it in to the dealer
   / Kubota f 3680 intermittent hst drive failure #7
You posted while I was adding pics, if you don't know when the oil filter and screen were last changed/cleaned, it would be a reasonable place to start. Many problems are caused by partially blocked filters/screens. Also check the suction hose for leaks, as previously noted.
   / Kubota f 3680 intermittent hst drive failure #8
Screen is 20, suction hose 50, filter, second pic 140.
   / Kubota f 3680 intermittent hst drive failure #9
Might be worth finding out what you paid for when it was previously repaired?
Ok just noticed the diagrams and will start with that. I just don’t want to damage the transmission so i am a little worried
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
J and L Cargo Express Shadowmaster Enclosed Trailer (A51039)
J and L Cargo...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
