Help identifying rotary cutter model?
   / Help identifying rotary cutter model? #1
Neveri
Ford
Hi!
I am new to the forum and hoping for help identifying the attached rotary cutter model? I need a part replaced and without the model it痴 proving difficult.
The cutter came with a 1966 ford tractor on the farm when we purchased it a couple of years ago.
   / Help identifying rotary cutter model? #2
Maybe a 100
   / Help identifying rotary cutter model? #3
I would say it is part of the 902 series..
Looks close, but I dont see the same protruding gearbox like mine has, above the belts?
   / Help identifying rotary cutter model? #5
That is a 902.. What do you think?
I still dont see this top piece there. I have tried finding something similar (with this gearbox on top ) on google but not seen anything close F85736C8-1B4E-4A94-90F0-18A3BB4C5379.pngyet.
   / Help identifying rotary cutter model? #7
If the top piece you are wanting to see is the sheet metal shield... you do realize just a couple bolts hold that on.. shields get lost all the time.
This is the part I need - housing for bearing 207krr3. The housing part # is what I am on the hunt for.
   / Help identifying rotary cutter model? #9
You have a New Holland dealer close by?
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
2021 KOMATSU PC490LCI-11 EXCAVATOR (A60429)
2021 KOMATSU...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
