Funniest thing I've heard all week
   / Funniest thing I've heard all week #21
Wouldn't the water quickly boil away and cause the solution to become more salty and more conductive?
Probably wise to stick your hand in now and then to make sure it's not getting too warm. I mean, if you're going to do something like that anyway. Just make sure you are well grounded. Moccasins soaked overnight in the same brine solution should work well. Safety first.
I have seen that too in the Phillipines on a video. They kinda look away, but they still get flashed. Not smart. I saw one Phillipino just using house current. I suppose the resistance of the distribution wiring acted as a current limiter of sorts, and he tapped in ahead of the two fuses the house had. All bad ideas. His welds look worse than my lousy gorrilla welds too. Just total bird poop.
your description of the welds kinda looks like some welds (sort of ) that I saw on a bench vise in this farmer's shed the other day. Was a setting where i wouldn't expect to find a welding machine very often. Maybe that's what they were using. I never heard if they work very well.
To be clear, I would be using a welding mask if/when I get around to trying this out just to see if it works.
   / Funniest thing I've heard all week #23
I am confident it will work, Just remember the stinger is hot with 120 volts, not transformer isolated, One mistake or a sweaty welding glove and you could be really hurting, or even killed. I suspect some chlorine gas will come from the salt water mixture also. I wouldn't breathe deep over the bucket. Salt being NaCl. So I suspect the electrolysis will liberate some chlorine atoms.
   / Funniest thing I've heard all week #24
You would be right, some chlorine does get liberated.
   / Funniest thing I've heard all week #25
Will it with AC? All electrolysis that I've done has been with DC.
   / Funniest thing I've heard all week #26
It will work, it's just that which gas is being generated at which electrode will cycle along with the current...
   / Funniest thing I've heard all week #27
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2013 Infiniti M37 Sedan (A50324)
2013 Infiniti M37...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
