Wood Chipper recommendations
   / Wood Chipper recommendations #21
Get one before prices go up as they hold their value really well . I sold my Woodmax 8m for close to what I paid for it after my projects were finished . I wish I had more of them as the phone didn't stop ringing until I took it off Craigs list . I'm 76 so I know all about the age thing . I really enjoyed using it though .
   / Wood Chipper recommendations #23
I'm in need of a new wood chipper... Used won't do - the last (only) one I've bought before had a Tecumseh motor, and literally blew a hole in the side of the engine within 20 minutes. Of course, the Craigslist seller was no longer to be found. I have approximately 10 acres with thousands of 'sucker' pines that fall over after a couple of years. In the past I've collected them and burnt them, but with so much danger of a forest fire around here, I'd prefer to simply shred them. Leaving them to rot is an option, but not a desirable one for me.
My basic requirements are:
Max 5" diameter, normally 4" or less
Gas powered
Portable
If high hp, electric start
Under $2000
If you have any suggestions or recommendations, I'd appreciate receiving them.
Thanks.
Nova Tractor Wood chipper
What about these wood chipper?
   / Wood Chipper recommendations #24
COME-ON, Plowhog - - I may be old as dirt, but even I would notice if they wore bikinis. And NO they do not...........
The parameters set by the OP - particularly cost - almost guarantees he will have to look at a used unit.
You BEST face this situation head on - Gem99ultra - you have ten acres with thousands of sucker pines - you want to go cheap and spend your time futzing with a "third world" chipper or spend the necessary $$$ and chip your trees ????? There are several brands that will last your lifetime with proper maintenance and chip your trees until H E L L freezes over.
The choice is yours - - Choose wisely, grasshopper.
FWIW - I initially had a stand alone chipper. I forget the brand - it was green. It just would not handle the load - 750 to 900 - small pines every spring plus half a dozen day-long sessions during the remainder of the year. The chipping blades would dull rapidly - the engine would overheat - finally ( and thankfully) it grenaded.
That's when I doubled down and bought my first PTO chipper - Wallenstein BX42S. I upgraded to the BX62S in 2011 after I upgraded to my Kubota M6040.
Eight years - 900+ small pines( 1" to 6" ) each of the eight years - still on the same side of the cutting blades - still sharp enough to slice my finger in a heartbeat.
Only maintenance - two zerks and coat the knife blades in heavy grease when done each time to prevent any rusting.
The only thing I could ask for - - girls in bikinis..... delivering ice cold beers.
Woodland Mills Canada. Check out the WC68 Woodchipper. I have it on my L3901. Awesome products and people to deal with.
I did go ahead with the Woodland Mills WC68; delivered yesterday. Today I'm doing the final assembly. With all this rain we're (FINALLY) getting here in Mid-Georgia, it'll be next week before I get to try it out. I wonder if one can run wet logs through a chipper?
Woodmaxx was my initial first choice, although more expensive, but they didn't seem to be interested in answering their phone nor replying to two eMails requesting pricing, delivery, etc. Woodland almost immediately responded, and saved me $200. Delivery from Buffalo, NY to Warm Springs was 7 days after placing my order. Heck - that's Amazon kind of service!
I'll be chipping up at least 1000 small pines this Fall, running the WC68 off of my Kubota L3400. Bikini girls and ice cold beer will have to wait :-(
   / Wood Chipper recommendations #27
Gem - wet logs will chip easier than dry. Water acts as a lubricant when chipping. Just be very careful of - nails, staples, metal fasteners in any old fence posts or the like and rocks, gravel, sand, dirt on anything else you chip.
Now - small pines are my forte. I thin my pine stands and chip almost that many every spring. That new chipper of yours will take on small pines just a kid eating a candy cane.
   / Wood Chipper recommendations #28
We bought a used tree company chipper through a Craigslist ad several years ago. Paid about $1500 for it and the 4 cylinder Ford engine sucked a quart of oil every hour of use but it worked well. A couple years ago we replaced the engine with a salvage yard one, same engine as a 1985 Ford Mustang 4 cylinder (salvage engine with about 80k miles cost us $500). It pushes about 80 HP and chips just about anything we can feed it.
The chipper itself is an Asplundh Chipmunk chipper. This is a Chuck-N-Duck chipper....you throw the brush into the chipper head and get the heck out of the way. The chipper head IS the infeed device. It will suck in a 4" diameter 25' long oak or maple sapling in about 8 seconds or less.
I don't have a picture of ours handy but this pic is very similar:
Good advice; thanks!
Now I have to figure out if and how to cut the furnished PTO shaft to size. Lots of video's on that, and all are different methods. Hopefully I'll be sling chips next week when the rain stops.
Again, thanks to all of you TBN members for the tips and advice. With those contributions, I'll graduate from being a total novice to an expert by this time next year.
   / Wood Chipper recommendations #30
GEM - - WHOA!!!!! The owners manual with your new chipper should have EXACT instructions on how to shorten your PTO shaft - if its necessary. If you do not have exact instructions - - let me know - - I will attach exact instructions to a post here. Don't play silly games with the PTO shaft shortening. At the very least - it can cause serious damage to the chipper or your tractor.
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
