Good morning!!!!
   / Good morning!!!! #79,781
ー wow Rick thanks
   / Good morning!!!! #79,782
Buckeye, did you go ahead and replace all the anti freeze in your ground loops? The low toxicity stuff approved for underground use is really expensive here.
I use food grade propylene glycol. I ended up not replacing the loop water.
   / Good morning!!!! #79,783
Good evening to all! Went up to 92°(thanks for the degree symbol trick!) from a low this morning of 52°. It was nice out until about 11am, then too hot. No breeze at all, made it feel that much hotter. No rain at all over the past few days, none forcasted until maybe Tuesday.
Got some good progress on some projects around the house. To hot to do much else.
Saw all the flooding going on in WV and Virginia, sad to see people loose their houses... Crazy weather going on around the country...seems to be extreme everywhere
Everyone have a great night and a peaceful Sunday. Prayers sent out for those needing.
   / Good morning!!!! #79,784
Good evening all. 72F for the start, calm wind some cloud. Sky cleared right off, Wind picked up and got gusty, and high temp was 98F. Bike ride this morning, 3 others joined up, 1 guy's bike quit shifting some we changed route to go back by his house and he changed bikes. Got hot before nap so no mowing today.
Don I just made sure my shoes were pointed straight and parallel to bike wheels. I have 10 of rotation on cleats so I have some "forgiveness" in my set up. Some people have some natural toe in or toe out and if your cleats have no float or rotation you need to adjust you shoes accordingly.
Tried the alt + 248 for degree symbol, don'y see it as I type, may have to change fonts to get it to work. Newbury,try changing fon't and see if you get betting results some fonts have errors and/or omissions.
Prayers for all.
   / Good morning!!!! #79,785
I got maybe 6 acres "slashed". Took 2 fallen post oak trees to the burn pile. Would have taken 3 but the last was a bit too big and my left front tire was a bit low on air.
It is so dry here, we are getting all types of ants in the house.
Worked on our Deere HPX Gator a bit. It won't start, has "ok" looking spark, will fire off and run on starting fluid. I have had the carb apart multiple times in the past to clean. The last 2 times, I should've put a new bowl gasket, but managed to get the old one squeezed into place. Ordered a new gasket, floats and the needle and seat....$50. I sure hope it runs when done cleaning and installing.
Tired, ready for bed.
Prayers for all my friends.
   / Good morning!!!! #79,786
That's what I did also. I went on a test 14 mile ride this morning and everything felt good. Looks like my average speed (including short stops) is about 12.5 MPH. I need to remember to stop the clock when I stop to get a more accurate (and faster) average.
   / Good morning!!!! #79,787
Not a breath of wind this morning, 15C/59F and the windows on the west side are dripping with condensation. No rain in the forecast, just another sunny day of around 26C/79F.
I am getting really spoilt by all this continious "good" weather, it seems so strange to be able to make plans on what to do outside without needing to constantly look at the sky. When I'd finished spraying yesterday, I sat in on the slider and looked right up to see swallows circling so high they were almost dots against the pale blue sky. I guess the insects must have trouble returning to ground when warm thermals want to take them for a ride.
   / Good morning!!!! #79,788
Good morning all, 67 going to 87 with a 20% chance of T-storms. Plan to take it easy today. Went grocery shopping yesterday and some in the house things.
Have a great day, prayers sent. Ed
   / Good morning!!!! #79,789
73 and foggy, good morning all and hope you have a peaceful Sunday.
David, hope that hurricane goes further South of you, better batten down the hatches.
I would sure like a day without rain and I'm sure some of you would love to have that day of rain instead.
   / Good morning!!!! #79,790
70° going to 91° today. Might mow even though I mowed Wednesday it’s very thick and ragged.
Kyle, do you maybe have fuel pump or filter issues?
Good day and God bless.
2016 CATERPILLAR 336FL EXCAVATOR (A52707)
2016 CATERPILLAR...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
More info coming soon! (A55851)
More info coming...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
(APPROX. 20) 4' X...
