1979 Ford 1900 4wd
   / 1979 Ford 1900 4wd #11
Those are great little tractors! I miss my 1710!
There are several drain plugs along the bottom of the transmission/rear axle that you have to pull to get all the fluid. If the tractor sets outside when it rains you will get water in around the shift boots straight into the trans/axle. Our simple fix was to set a 5 gallon bucket over the shifters. It stopped the water getting in.
That's probably what happened, they had it sitting outside after moving it from their property. Thanks for the info on the drain plugs.
   / 1979 Ford 1900 4wd #13
   / 1979 Ford 1900 4wd #15
These are great tractors! I saw somebody said they are tanks. Thats a fact. The parts are high but that being said all tractor parts are
Its been a while since your origional post. If ya bought i hope the lil blue tractor is treating you well.
   / 1979 Ford 1900 4wd #16
It's been a girl's best friend! I just need to figure out how to get the lights functioning. ��
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53472)
2022 JCB 3TS-8T...
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
