1979 Ford 1900 4wd
   / 1979 Ford 1900 4wd #11
Those are great little tractors! I miss my 1710!
There are several drain plugs along the bottom of the transmission/rear axle that you have to pull to get all the fluid. If the tractor sets outside when it rains you will get water in around the shift boots straight into the trans/axle. Our simple fix was to set a 5 gallon bucket over the shifters. It stopped the water getting in.
That's probably what happened, they had it sitting outside after moving it from their property. Thanks for the info on the drain plugs.
   / 1979 Ford 1900 4wd #13
   / 1979 Ford 1900 4wd #15
These are great tractors! I saw somebody said they are tanks. Thats a fact. The parts are high but that being said all tractor parts are
Its been a while since your origional post. If ya bought i hope the lil blue tractor is treating you well.
   / 1979 Ford 1900 4wd #16
It's been a girl's best friend! I just need to figure out how to get the lights functioning. ��
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Service Truck (A51692)
2019 Dodge Ram...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
UNUSED AGT QUICK ATTACH AUGER SET (A51248)
UNUSED AGT QUICK...
HOBBS MODEL-666 16' HAY RAKE (A51247)
HOBBS MODEL-666...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
