Weed & brush spraying
   / Weed & brush spraying #11
Even if the mower can get under the fence line it cannot get up against the post. So you are left with either weed wacking them or spraying.
Interestingly my little garden tractor lawn mower can get under the fence line enough. So if I mow down both sides it gets under it. Of course not close up to the posts. However my fence is 3 wire of electro braid so it does not get near the ground like it sounds OP's fence does.
I like the look of having the grass. I am going to spray around the posts though because I am NOT weed wacking around 400 of the things.
   / Weed & brush spraying #12
Gly,24d and atrazine does a good job most of the time . I will use remedy if its a harder weed to kill. use good surfactant . The folks that admonish the use of chemicals are the same one getting plastic straws banned. Most are a little "touched" in the head.
   / Weed & brush spraying #14
ZTR's and tractors POLLUTE!!
Get out there with a pair of scissors!!:sarcastic:
But make sure it is scissors that are all flint knapped, as the making of plastic handles and stainless steel blades is also a pollutant.
   / Weed & brush spraying #15
Round up and 24-d probably only cause cancer...in lab rats....in California.
Its a good thing that neither I nor the OP are lab rats.....or live in California.
   / Weed & brush spraying #16
Mow it and stop poisoning the ground with chemicals that kill bees, bugs, birds, and pollute. ZTR or tractor mowing.
:thumbsup: Welcome back TC! :drink:
I decided to go with Crossbow to kill the vines that are climbing on my fences. The recommended amount of concentrate is 1.5 ounces per gallon of water as compared to RM43 which is 6 ounces per gallon. And RM43 kills everything which I may not want to do in some areas. Will see how that works out. Some reviewers complained that it took a while to see results.
   / Weed & brush spraying #18
I sprayed 20 acres of hayfield last night with roundup to kill some bahia grass . The first step to recovery is admitting your have a problem, right?? I admit I have a problem and the only solution is to burn it down with Chemicals.
   / Weed & brush spraying #19
I use 41% generic round up with 15% surfactant
I buy 5 gallons at a time and have shipped to my door from rural king for about $90.00
   / Weed & brush spraying #20
**** that Rm43 is just generic roundup at 43% concentrate. $100 for 2.5 gallons is a rip off. I pay $49 or so for 2.5 gallons of the same concentrate. That stuff is a rip off.
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
