Carter EZ Hitch vs Quick HItch or Pats Hitch
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Forgive the ignorance but I am a new tractor owner trying to make my experience less frustrating.
The reading I have done on the site does not shed a lot of light on the impact of adding a quick hitch and its effect of the length of the PTO shaft. Both the Quick hitch and Pat's seem to add about 4". Will I need to add new PTO shafts to my powered attachments? Currently running a King Kutter brush hog and JD rototiller.
I have seen a PTO extender that adds just over 4". It seems like the way to go as it will make hook up easier. What are others doing/using?
Amazon.com: All States Ag Parts PTO Adapter - Quick Release Collar/Coupler 1-3/8" 6 Spline Female 6 Spline Male PA9 PA-9: Garden & Outdoor
The Carter EZ hitch, adds some height over the links so the PTO extender is not needed, and also has the benefit of maintaining the lift capacity of the 3pt by keeping the load closer to the lift arms.
Welcome to CARTER AND SON'S TOOL AND DIE
I am hoping to use cut down pallets to move firewood using the TSC Carry All. At 24" beyond the lift arms, my 3PT is rated at 840 lbs so not a lot of capacity. 1/6 th of a cord.
Thanks for any feedback
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #2
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #3
I'm using a first generation set of Pat's. I have never taken them off. On some implements you may need a longer PTO shaft or an extension. I was lucky, only 2 of attachments use a PTO shaft and it was long enough to use.
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #4
Seems to me that one of the important factors in using PAT's or Carters is whether you have stabilizers on the 3 point. Without the stabilizers, you fight the turnbuckle widths for mounting an attachment. The four inch increase could be enough to need the extender. I guess it would depend on how close the original shaft was cut to a usable length as is.
As a newbie of not long ago, I have had the same experiences. My Carter's is has been replaced with a PATS on one tractor and a LandPride QH on the other tractor. The Carter is well made and did serve some time for me.
Cheers,
Mike
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #5
I've owned a HF quick hitch....and discarded it after a short time. Went to Pat's about ten years ago.....and would not change for another brand. I just (last week) bought a new tractor with the telescoping links.....and I'm uncertain if I will "live" with them or put the Pat's on. I think adding the Pat's to these telescoping links will be the real deal..... Anyone with experience here?
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #6
I've had a set of Pat's for about 12 years. Two pto implements that did not need new shafts and I have no issues hooking up any of my implements due to width variations.
Very happy.
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #7
I have the harbor freight qh. Love Love Love it. Need to get a pto extender for the tiller. Not for the bush hog.
If your implements are newer the hf type should work. I tried a pats clone. Problem was it did not have a spreader bar. So it sucked. I am pretty sure if I had gotten the pats w the spreader bar I would have kept it.
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #8
I bought and fitted the PAT's devices to the little Kabota JUST to facilitate PTO shaft length between several tractors.
They Work OK. Somewhat easier to hitch up than right off the balls, but barely.
It depends on the implement pins.
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #9
I have six implements that go on my 3-point. Some are a lot easier to attach/detach than others. As much bitching, complaining and custom modifying as goes on with these "quick attach hitches" - - I'm just happy as a clam that I choose to not go that direction.
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #10
I have the HF style QH but Mahindra brand. Makes hookups a lot easier. For blades, landscape rakes, and such that when unhooked, the top falls to the ground, you'll need some kind of stand that keeps it level to get the full benefit of easy hook-up.
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #11
Since I got QH first (BE Ag & Industrial) I simply setup all my attachments when I acquire them to fit QH and after that no connect issues....
One of the issues it seems with a "new" QH and already acquired implements is people seem to think it will magically fit and are grumbling it does not.... First thing to do when acquiring a QH is modify (cut-drill-weld) implements to be QH compatible... Then life is QH good....
One issue with buying new attachments a lot of manufacturers have not caught up with the "quick hitch compatible" trend...
Dale
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #12
I have 2 QH's, a HF one and the Farm Hand from Lee Agra. The HF one works just fine with everything and I didn't need to replace the shaft on the brush cutter. The Farm Hand is a beefmaster! Very heavy duty, has 3 sockets for a Reese hitch style extension or bale spears, has 2 welded on grab hooks from the factory, came with a boxful of pins, bushings and the elusive "flex link" thingy, works with CAT I and CAT II tractors, AND is MADE IN THE USA!!
   / Carter EZ Hitch vs Quick HItch or Pats Hitch #13
Pat's has been good to me. No drive lines have had to be extended.....top link yes but TSC has them for less than 30 bucks. The thing I really like about Pat's is the bar that sets the width. Using mostly with older Fords which only have chains for lift arm stability (floppy), the spacer is a gem....some suppliers sell the couplers with the spacer a 20 buck extra.....ASC doesn't.
On your lift capacity, check where your equipment lift is measured....at the lift arm pivots or out from them. Remember lift is feet x pounds, like torque, a "Moment of Inertia".
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2018 John Deere TX (A53317)
2018 John Deere TX...
2019 KUBOTA U35-4 EXCAVATOR (A60429)
2019 KUBOTA U35-4...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
BOMAG TRENCH COMPACTOR (A60429)
BOMAG TRENCH...
