Third function
   / Third function #11
That is great feedback. The factory Branson option is not well documented on the web so having real world experience is priceless.
I have purchased my new tractor to help clean up the limbs, branches, and forestry mulch all over my property.
My tractor will come with a grapple and the factory diverter installed. I am very excited to put this tractor to work.
I appreciate your feedback.
   / Third function #12
This is interesting, I was not aware that Branson offered a "factory" diverter valve.
I was under the impression that they where all dealer installed from kits with quite a bit of variation in components.
   / Third function #13
I learned of the Branson option through Dave's Tractor. Another user asked for the information for the 3rd function and rear remotes. Dave provided the Branson part numbers. The 20 Series 3rd function part number is: BZ00452 and the Dual Remote kit is: RMK2-20. The two kits, according to Dave, costs about $1500.
Dave went on to say Branson is 30%-50% cheaper than the other OEM's for this setup. This data is from a post on 4/1/2016 so prices might have changed or part numbers upgraded.
https://www.tractorbynet.com/forums/century-branson/355332-20-series-third-function-fel.html#post4417455
   / Third function #15
Pulling up an old thread, does anyone have the factory Branson 3rd function diverter installed? Are there any photos of this installed? I can't find anything on the web and very little here in the Branson forum.
I read a post that the W.R. Long kit doesn't work the same on a Branson because the system doesn't keep constant pressure on the power port so you only get 2 functions a time. Of course this post ended abruptly without follow up or photos so I'm no more informed.
When searching around I only see the Kubota's getting 3rd functions and the photos I've seen for EA with their wicked grapple just show the tractor at distance holding up a tree. I am taking possession of a new 5220R this coming Friday with the Branson factory diverter.
If anyone has the factory option and can speak from experience, with photos, I'd greatly appreciate it.
I had the 3rd function installed by Branson on my 4720CH. This is not a true 3rd function, but rather a diverter valve. It basically steals the hydraulics from my bucket when I press the momentary switch on the loader control stick.
   / Third function
I have my doubts about a true thrid function allowing simultaneous operation of the grapple and the loader. I did a test of raising the 3pt hitch while raising the loader and the 3pt doesn't go anywhere. I suspect that the loader valve is sending most output to the tank port rather than the PB port when it is operating. You can try it yourself. It's possible that I did the test wrong or my loader valve is different than others.
A reason to get a true 3rd fuction anyhow would be that you prefer the ergonomics of that system vs the diverter where you're using the same motion that operates curl and dump. Some may consider the all on/all off operation of a 3rd function to be a drawback but I find that I have little need to feather the grapple (mine's connected to a rear remote for now). YMMV etc etc.
   / Third function #17
Thank you for the photo Warsign. That looks good. How have you used it? Do you have any regrets over a traditional valve?
PapeCAT
I found that document this morning. I visited their website, but they don稚 lost Branson in their products. I really like the cost of the dual rear remotes. I would like to add those to my 5220 too.
   / Third function #18
When multiple functions are used the flow capacity of the pump may be reached. That's what occurs when your 3pt won't move. It's last in the chain of events.
My M9540 has a large enough pump volume to successfully utilize it's true 3rd function. Lift, curl and grapple close will all work at same time.
   / Third function #19
That makes sense Ovrszd, the M9540 has 23.1 gpm total flow with 17gpm for hydraulic and an additional 6.1gpm for the steering. By contrast the 5220R and has 16.1 gpm total split 11.1 gpm for the main pump and 5 gpm for steering. The 3725H is just 15.4 gpm total flow. I can see where additional flow would help the overall hydraulic function.
   / Third function #20
PapeCAT
I have yet to buy a grapple, so I don't have any input as far as functionality. It is certainly on my list of items to get. The price point of $625 US installed was an easy sale, regardless.
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
2002 Isuzu NPR-HD 14ft Box Truck (A48081)
2002 Isuzu NPR-HD...
Headache Rack (A50860)
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2018 Chevrolet Bolt EV LT Hatchback (A48082)
2018 Chevrolet...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
