Wheel bolt needed for mower deck Rck54p23bx
   / Wheel bolt needed for mower deck Rck54p23bx #1
bbbacres
Kubota BX 2360, Kubota L185 deisel 4x4
I use a Mowing deck Rck54p23bx with my Kubota BX2360. I found one of the mowing deck wheels laying on the ground. The pin or bolt that goes through its center had sheered off and I need a new one. I'm not finding it on the parts diagrams, tho it must be an often used part. Can anyone help me locate this? Also, do prices vary on these things? I appreciate your time. See pic. Kubota wheel bolt for mower.jpg
   / Wheel bolt needed for mower deck Rck54p23bx #2
I use a Mowing deck Rck54p23bx with my Kubota BX2360. I found one of the mowing deck wheels laying on the ground. The pin or bolt that goes through its center had sheered off and I need a new one. I'm not finding it on the parts diagrams, tho it must be an often used part. Can anyone help me locate this? Also, do prices vary on these things? I appreciate your time. See pic.View attachment 566981
I believe that is called a shoulder bolt. Should be available at any lawn and garden shop or hardware store.
Thank you for the tip. The right phrase means everything. Found it right away. PS ACE Hardware did not have it, other places might. But I found it on line at both Messicks and Coleman Equip/ I appreciate the courtesy.
   / Wheel bolt needed for mower deck Rck54p23bx #4
Your dealer should stock them. I have replaced many on my 2002 mower deck. It is the weak link when you strike something with the wheel. Make sure to use nylon bolts to hold it on or you will be hunting your wheel later!
   / Wheel bolt needed for mower deck Rck54p23bx #5
I think you refer to NYLOCK NUTS or any other self locking style of nuts (not bolt).
   / Wheel bolt needed for mower deck Rck54p23bx #6
I just found the picture of the shoulder bolt used on your mower deck,I must say that it looks like the weak link. Also that bolt is used in 19 other decks.
Guess that's why they keep 200 in stock, you might consider ordering a few spares.::D
   / Wheel bolt needed for mower deck Rck54p23bx #7
Good advice, if you broke one you WILL break more, get some spares
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
