Recomendable Removable Earth Anchors for Cupola
   / Recomendable Removable Earth Anchors for Cupola #1
fidowanttobe
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Will be setting up an old galvanized barn cupola as a yard ornament and would like some recommendations for earth anchors to hold the light sheet metal structure to the core of the earth. Gets kinda windy up here at times. Bottom will be setting on 6x6 green treated skids on 2 sides, so they are what I want to anchor down. Wife would like it NOT cemented down, just in case of??? I have 3" topsoil and then pure sand forever. Any ideas guys? Thanks.
   / Recomendable Removable Earth Anchors for Cupola #2
How large is this cupola?
If you don't mind some big holes, drop in an old mounted tire with cable attached, then backfill. Repeat as needed, maybe one at each end of each 6x6. If you have boulders available, that would work instead of a tire.
Bruce
   / Recomendable Removable Earth Anchors for Cupola #3
You can buy the auger style earth anchors at places like Home Depot and Lowe's.
4 - 30" long anchors can be bought at HD for less than $30.
Two for each 6x6 might be sufficient, but depending on the cupola size ( a LOT of wind in Mandan, ND), four earth augers for each 6x6 would be better.
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
JOHN DEERE Q820M LOT NUMBER 244 (A53084)
JOHN DEERE Q820M...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
2024 JOHN DEERE 35P LOT NUMBER 110 (A53084)
2024 JOHN DEERE...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
