Recomendable Removable Earth Anchors for Cupola
   / Recomendable Removable Earth Anchors for Cupola #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Will be setting up an old galvanized barn cupola as a yard ornament and would like some recommendations for earth anchors to hold the light sheet metal structure to the core of the earth. Gets kinda windy up here at times. Bottom will be setting on 6x6 green treated skids on 2 sides, so they are what I want to anchor down. Wife would like it NOT cemented down, just in case of??? I have 3" topsoil and then pure sand forever. Any ideas guys? Thanks.
   / Recomendable Removable Earth Anchors for Cupola #2
How large is this cupola?
If you don't mind some big holes, drop in an old mounted tire with cable attached, then backfill. Repeat as needed, maybe one at each end of each 6x6. If you have boulders available, that would work instead of a tire.
Bruce
   / Recomendable Removable Earth Anchors for Cupola #3
You can buy the auger style earth anchors at places like Home Depot and Lowe's.
4 - 30" long anchors can be bought at HD for less than $30.
Two for each 6x6 might be sufficient, but depending on the cupola size ( a LOT of wind in Mandan, ND), four earth augers for each 6x6 would be better.
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55787)
2023 Caterpillar...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A54756)
PAIR OF DIAMOND...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
