Max 28 turning off at high rpm's
   / Max 28 turning off at high rpm's #1
jsn329
Mahindra max 28xl
My tractor runs fine if the RPM's are not maxed out, Once I open the throttle all the way after 10-20 mins the tractor shuts off. It will start up normally after that, but will shut off again if I open the throttle all the way. It sounds as if the key is turned off. Any ideas? I was not sure if the fluid solenoid would cause this. I know I have heard a lot of people with a mahindra having fuel solenoid problems.
Thank you
   / Max 28 turning off at high rpm's #2
I believe you're referring to the fuel shut off solenoid...
Otherwise you'll need some MAX knowledgeable members to weigh in on the solution.
   / Max 28 turning off at high rpm's #3
Thank you
Is your fuel screen still in the tank filler neck ??? I see them get pushed down into the fuel tank with long funnels. The screen will block the fuel pick up. :confused3:
It is still in place thank you
   / Max 28 turning off at high rpm's #5
Try leaving fuel cap a little loose to let air in.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
