Max 28 turning off at high rpm's
   / Max 28 turning off at high rpm's #1
jsn329
Mahindra max 28xl
My tractor runs fine if the RPM's are not maxed out, Once I open the throttle all the way after 10-20 mins the tractor shuts off. It will start up normally after that, but will shut off again if I open the throttle all the way. It sounds as if the key is turned off. Any ideas? I was not sure if the fluid solenoid would cause this. I know I have heard a lot of people with a mahindra having fuel solenoid problems.
Thank you
   / Max 28 turning off at high rpm's #2
I believe you're referring to the fuel shut off solenoid...
Otherwise you'll need some MAX knowledgeable members to weigh in on the solution.
   / Max 28 turning off at high rpm's #3
Thank you
Is your fuel screen still in the tank filler neck ??? I see them get pushed down into the fuel tank with long funnels. The screen will block the fuel pick up. :confused3:
It is still in place thank you
   / Max 28 turning off at high rpm's #5
Try leaving fuel cap a little loose to let air in.
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
