Your Land is my Land
   / Your Land is my Land #532
As luck would have it, played hockey with an attorney who specializes in adverse possession cases.
One thing he said was interesting: there is a certain level of trespass expected between adjoining neighbors.
   / Your Land is my Land #533
I wish I heard the final chapter as well. Dang TBN preachers.
   / Your Land is my Land #534
I can see that. In cities, properties are so close together, sometimes it's necessary to go on the adjoining property to maintain your own. You may have to step on the neighbor's driveway to edge or trim your lawn, or foot a ladder to paint your house for example. Out here in the country, one of my neighbors has an electric fence for animals, He want to keep grass away from it to avoid a potential for grass fires. The property next to his is a crop field that isn't mowed up to the fence. He goes on their side with his riding mower to mow/trim grass away from the electric fence wire.
If I ever move to another place and build (which I never will), I plan to set my fence 6' inside the property line so I can do that without encroaching though.
   / Your Land is my Land #535
Unfortunately, then your neighbor will use that 6 feet.
   / Your Land is my Land #536
^^ The plan would be to mark it with another set of T-posts only, easy to mow/trim against/around without going over. But It would be an area where the neighbor probably would never come that close to the fence line to begin with. Neighbors here can be a mile apart and own hundred of acres, some of which they rarely see.
1831 (A51247)
1831 (A51247)
2013 PETERBILT 337 FLATBED (A55745)
2013 PETERBILT 337...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A56129)
2022 BRAZ0 40FT...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2007 Ford F-350 Pickup Truck, VIN # 1FDWW37P77EA65949 (A54865)
2007 Ford F-350...
