Ford 3000 won't crank to start
   / Ford 3000 won't crank to start #1
rwridle
Ford 3000
My Ford 3000 stalled while cutting thick brush. During the restart it cranked slowly. I charged the battery and it would not turn over to start. Verified the battery is good and ended up replacing the starter at the advice of local Ford dealer. Now it won't turn over. Voltage regulator checks out fine and
I cleaned the contact points. I will post a link to a video of the problem. I think there is something wrong with the starter, and would appreaciate any advice or experience with the same problem.
   / Ford 3000 won't crank to start #2
You didn't say diesel or gas. If you were mowing at PTO rpms you had a lot of kinetic energy built up in the rotating blade. Whacking something hard could have sent a shock wave all the way through your gear train to and through your engine. If you have any gears locked in place with a Woodruff Key, you could have sheared, or partially sheared it, changing the engine/injector/spark timing.
I'd try to restart it with the clutch depressed to disconnect everything from the engine.
Get a voltmeter and put it across the starter, one lead on the 12v input lead (⅜" copper stud) and the other lead on the STARTER HOUSING. Crank the engine and see if you have 10v while cranking. If not one of two things: Starter offering too much load to the power supply system, or you have a bad electrical connection somewhere between the battery and the starter stud/case.....one good place to check is this:
The battery - lead is probably grounded to the tractor frame on the right side. If it is, move it over to the starter and put it under one of the starter mounting bolts having shined up the area and the lug before mounting. Check the + lead at the starter ⅜" stud and ensure it's clean (inside) and tight.
Next problem could be worn brushes in the starter. Some starters have a metal band (dust cover) around them whereby you can remove it and see the condition of the brushes. Commutator could be glazed over requiring burhishing to shine it up and improve conductivity.
If all that's ok then something in the engine has changed. I'd pull the injectors/spark plugs and see how it rolls over. If not too good then something is binding. If good then you need to check timing.
Wow, this just goes on and on. Get that done and if you still aren't there come back and we will go some more.
   / Ford 3000 won't crank to start #3
The secquence of events don't make sense(esp what you say about regulator). Explain how you tested regulator on a tractor that won't even crank,much less start and run. After hearing how you managed to check regulator,we can talk about getting tractor running.
Thanks for the replies! Tractor is diesel. I cleaned the regulator as part of checking it out to ensure it was not burned or damaged. The inside of the regulator was clean, and the points opened and closed freely. The wear looked normal. I ruled out the regulator.
I think either the starter is stuck in the flywheel or there is some thing with the PTO and or gears binding.
I also will pull the injectors at the cylinders and try to turn it over. This is my first time troubleshooting a diesel.
Also: It rolls freely with the clutch depressed or in neutral. I tried to jump start it by pulling it behind my truck with my cousin. It would not start.
A couple of pictures of the new starter and how it is wired. 20180825_145808.jpeg20180825_092729.jpeg
   / Ford 3000 won't crank to start #7
I watched the video. I could hear the way it's banging in gear. First thing I would do is try and turn the crank by hand. The Bendix sounds like it's being thrown out and hitting the flywheel with a good amount of force, but no cranking. Do you have an amp probe? Is the battery cable getting hot while cranking? What do YOU think caused it to stall? You think the load was too great? Did it stall abruptly from hitting something? What is the oil level and condition?.. and coolant level.? Was it running hot when it stopped running? What's your battery voltage at? Are you trying to crank it over with the PTO engaged? Need just a bit more information before coming to an accurate diagnosis, but I truly hope we get you back up and running.
It stalled slowly in thick grass after a normal start. The tractor was just getting warmed up. Oil level was actually a little overfilled, but I had run it 7 hours the weekend before with no problem. I corrected the oil level. Battery cable does not get hot while cranking. PTO is not engaged, nothing is attached to the PTO. I will measure battery voltage and report this afternoon. Thanks!
   / Ford 3000 won't crank to start #9
Yeah - test the battery - a Load test would be more definitive than a simple voltage test
If you can get a socket on the crankshaft damper bolt make sure the crankshaft is not locked.
If the engine is not stuck I would do some current checks of the main starter cable with an inductive dc amp meter while cranking.
By saying there is no heat generated while attempting to crank it sounds like a bad main cable or termination That also includes the - cable and it's termination. This assumes the battery has passed it's tests and engine is not stuck.
   / Ford 3000 won't crank to start #10
the voltage at the starter when cranking will tell you what's going on..
Thanks again for the feedback! Here is an update after more troubleshooting this morning:
1) The starter solenoid is bad. Confirmed by removing and bench testing. Also compared it to the old starter, which works correctly.
2) The flywheel does not turn with the wheels when it is in gear.
3) The PTO does not turn either. See new video. Ford 3000 motor siezed? - YouTube
Anyone have experience with a seized motor and how to un-seize it?
Why does the PTO not turn with the wheels when the PTO is engaged?
Am I looking at a major shop repair or is this a do-it yourself project? The tractor only has about 350 hours on it.
   / Ford 3000 won't crank to start #12
if it is truly seized, then ATF mixed 50/50 with acetone in the cylinders with the injectors removed may do it. let that sit overnight to make sure it works, if it don't, then a combination of strong acids, which is used to eat away a bit of metal to loosen a broken tap in a machine shop, but would work as a last resort here, may be required, then a teardown to determine what needs to be replaced is needed after that extreme measure, I'll post the ingredients if you really need it, but you have to be VERY careful, as it's a mixture of VERY strong acids.. possibly your oil pump has failed?..
   / Ford 3000 won't crank to start #13
With the wheels jacked up, turning one wheel at a time will not make the engine turn over. The is an "open" rear end. Each wheel turns independent of each other. If that tractor has a way of "locking" the rear
end, then you could tell if the motor will turn over.
   / Ford 3000 won't crank to start #14
I would take it out of gear and make sure the PTO is disengaged while you have it on stands .
Remove the starter and get a pry bar and see if the flywheel can be moved a tooth at a time, Using a socket and ratchet or breaker bar on the crankshaft dampener bolt is also a good way to determine whether the engine itself is stuck .
Not a fan of trying to move the crankshaft by trying to turn the pto or wheels not sure that would work with man power.
I tried the prybar on the flywheel teeth. It wouldn't budge.
Before jacking it up and turning the wheels while looking at the flywheel, we towed it behind my truck. The motor would not turn over and we dug ruts and spun truck tires.
   / Ford 3000 won't crank to start #17
Oh , OK got it , have you had the tractor for a long time or is this a new acquisition?
It has been in the family since 2000. My dad bought it. There is a sticker under the hood where he changed the oil at 50 hours. In 2011 it showed 100 hours, but the hour meter no longer works. I estimate I put 150 hours on it in the last 8 years. It has been a good tractor, very reliable.
   / Ford 3000 won't crank to start #19
On the + cable, what is that 90 degree bend? Is the cable cut? Where is the - lead attached on the starter end.
On the throwing the Bendix and then no whoopie, again smells of worn brushes (if not that kinked wire) that have adequate contact area to toss the Bendix (being it takes little amperage to do that) but when you start asking for 200 amperes or somethere around there the brushes/brush armature connection can't handle it. Course if the engine is frozen, all bets are off.
Did you put a volt meter on the starter like I mentioned while cranking and if so what was the voltage".
This thing is getting confusing: Battery good or bad....will it hold 11v across the terminals while supplying 200 amps....battery tester will determine that. Did you do that?
You were running ok and it quit. Now it won't start, nor even turn over but has plenty of oil. But the engine turns over ok with the load (gear train) disconnected via the clutch? Which is it? Crowbar won't roll the engine.....was the clutch pushed in when you did this test essentially disconnecting the driveline from the engine....aka are we chasing a battery problem, engine problem, or driveline problem?
Is there a problem in the drive train? What kind of PTO does it have.....your question about the PTO not turning if the rear wheels are turning?
Did you have a look at the oil in the tranny and hyd-differential? Milky? How about the levels, were they where they were supposed to be?
   / Ford 3000 won't crank to start #20
On the throwing the Bendix and then no whoopie, again smells of worn brushes (if not that kinked wire) that have adequate contact area to toss the Bendix (being it takes little amperage to do that) but when you start asking for 200 amperes or somethere around there the brushes/brush armature connection can't handle it. I didn't watch the movie.
Sorry- guys but if the crankshaft can't be moved with a pry bar there are bigger concerns but the starting system will have to be dealt with eventually.
That sure sounds like a SUPER LOW hour 3000
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
Kubota L3130 (A53317)
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
