Vintage Gravely 30 inch Mower Deck Lube Question:
   / Vintage Gravely 30 inch Mower Deck Lube Question: #1
Leighs
Gravely 5460
Gravely Mower Deck Lube-2.jpgREF.: Part # 23075 30 inch Rotary Mower Deck Lubrication question:
The Manual, FORM NO. 37063 (7-86) States that Multi-Purpose Grease should be added until it "shows at the Mower Shaft--Under the Mower Deck.
Applying grease through The Grease fitting, P/N 271434, simply deposits the grease into the P/N 22513 Gear Housing, & on to the P/N 22518 bevel gear, without pressure.
In order for grease to be forced down to be seen at the P/N 22522 Seal below the Mower Deck, the entire P/N 22513 Gear Housing, & P/N 22514 Swivel Casting would have to be completely packed with grease, & the grease forced under pressure past the Bevel Gear, Pinion Gear, upper & lower bearings & races before it could be forced past the P/N 22522 Seal, to be "seen at the bottom".
QUESTION: Is the entire P/N 22513 Gear Housing, & 22514 Swivel Casting meant to be entirely pre-packed with grease? Gravely Mower Deck Lube.jpegGravely Mower Deck Lube-3.jpeg
   / Vintage Gravely 30 inch Mower Deck Lube Question: #2
Funny. I had one of these on the 12 hp Gravely I had for nearly 4 years and never greased it. It was the most used implement. I maintained 3 miles of trails and mowed the lawn and even my neighbor's with it quite a bit.
Ralph
I bought the unit, used, about 30 years ago, & only pumped a few shots of grease into that location as a yearly maintenance routine, & never had any problems.
Recently, the cotter-pin in the upper Spindle attach nut sheared, & I had to take the Gear Housing loose from the Swivel Housing for repair.
The Spindle turns on upper, & lower Cone bearings/ Races; which were both still packed with grease, & showed no significant signs of wear.
I wanted to put it pack properly as per the manual; but "oddly", the manual states to simply pump a few shots of grease through the Grease-fitting, which simply deposes it onto the Bevel Gear, but no mention of periodically re-packing the Bearings in the conventional way?
I don't know how that grease would be expected to gravity feed, passed the Bevel, & Pinion gears, down the Spindle, & past the Bearings & Races, & through the lower Seal, to be seen from the bottom; & I've never noted any grease at the lower seal location?
   / Vintage Gravely 30 inch Mower Deck Lube Question: #4
Pack it full about once a year if it needs it..
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
(INOP) KUBOTA ZD326 ZERO TURN LAWN MOWER (A51247)
(INOP) KUBOTA...
2004 GMC Envoy SUV (A51694)
2004 GMC Envoy SUV...
2013 CATERPILLAR CT660L SBA 6X4 ROAD TRACTOR (A51247)
2013 CATERPILLAR...
2016 Chrysler Town & Country Van (A51694)
2016 Chrysler Town...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
