Crossbow herbicide Vs. Rural King "Crossroad" herbicide
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Crossbow herbicide is very difficult to find in north/central Florida.
The Rural King in Gainesville, Florida regularly inventories Agri Star "Crossroad" herbicide:
2,4-D -----------------34.4%
Triclopyr BEE---------16.5%
Inert Ingredients-----49.1%
Similar? Better? Worse?......than Crossbow?
Crossbow is the only herbicide which killed spreading native Florida Blackberries in one application for me, in part of an ornamental, non-grazed pasture. I applied Crossbow with a one-gallon sprayer.
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #2
The Rural King in Gainesville, Florida sells Agri Star "Crossroad" herbicide:
2,4-D -------------------34.4%
Triclopyr BEE----------16.5%
Identical active ingredients (and less expensive):
From Crossbow label: http://www.cdms.net/ldat/ld02h006.pdf
Steve
Thank you, Steve, for your definitive responce.
I have been buying Rural King Crossroad herbicide when in Gainesville, Florida, 40 miles from home.
The last two visits, about two weeks apart, Rural King was totally out-of-stock on Crossroad.
Today I was in my local Tractor Supply store and chanced to read the label on:
GORDON'S BRUSH KILLER
One Gallon - Makes up to 64 gallons of spray solution.
I use 3 ounces per gallon of water = 42.6 gallons of spray solution.
Triclopyr~~~~7.81%
2,4-D~~~~~16.49%
Dicamba ~~~1.38%
Inert~~~~~73.2%
One gallon concentrate $49.99.
I have found this Gordon's herbicide ALMOST as effective as Crossbow and Crossroad. I have not sprayed GBK on Florida pasture blackberries, but I will.
Any illuminating comments on Dicamba, which I am not familiar with?
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #5
I ran into the same issue finding Crossroad herbicide last year. I don't use a lot of it, but when I need it most so does everyone else and the shelves are bare for months. I bought a few gallons last winter when they had plenty at RK. I use it mainly for Multiflora Rose, berries, and poison ivy. I also use for black locust occasionally, but that's an uphill battle. I even used Crossroad in a boom sprayer on an area of lawn that was choked out by ivy and difficult weeds. I think that Gordon's product would work for me, and I use some of their other products including Trimec, but I'm comfortable getting just the right mix using Crossroads so it's tough to change.
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #6
I googled "Dimethylamine dicamba" and got quiet a lot. It is basically a broad leaf specific herbicide.
The results also provided a link to the National Pesticide Information Center where a technical fact sheet can be found.
Hope this helps.
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #7
all of the RK herbicides I have used have done just as well as the "name brand" But, 2.5 gal of crossroad is $99.
2.5 gal of gly (imitator) is $35. 2.5 gal of 24d Amine is $30. $65 for the 2. 2oz of each per gal to me has done almost as well as the crossbow did. If its something really woody I will add some triclopyr to the mix.
2008 GMC SAVANA 16' BOX TRUCK (A51247)
2008 GMC SAVANA...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2025 Mower King SSRC (A50123)
2025 Mower King...
(APPROX 72) UNUSED PALLET OF LANDHERO WHEEL STOPPE (A51248)
(APPROX 72) UNUSED...
TRANSMISSION OFF CATERPILLAR D7R CRAULER DOZER (A51248)
TRANSMISSION OFF...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
