sd455dan
Elite Member
- Joined
- Oct 23, 2012
- Messages
- 4,787
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
It would be for general welding , repairing something that's broken. Just looking for a basic welder that I can learn on at an affordable price.
General welding is pretty general
Affordable price I get that for sure.
I would check out the local craigslist and try and find a good AC/DC stick welder with leads for around $200.
With the right rod you can weld most any material from steel to cast iron, stainless, to aluminum -although stick welding aluminum is probably the last method I would chose.
Since you wired your garage for 200 amp service, you could look for what is posted above and go up a level and try and find an older American made stick/tig welder
you have to have space- because they are generally a larger footprint welder you gain several capabilities such as AC tig welding in addition to DC tig.
Now you can Tig weld steel Plus Aluminum and other metals that require AC Tig.
It also buys you more welding power for big or thick metal jobs and welding any thicker Aluminum requires power.
If you were in my area I would give this a look (i have an earlier model of this)
Lincoln arc welder Tig 3/3 ac/dc welder - tools - by owner - sale
Not all shiny- but comes with everything and even a pro cooler. for $650 obo but it isn't portable
If you will just be doing smaller jobs with steel like exhaust welding, mower decks, building say a welding cart and repair of 1/4 or less...
a new 150-200 amp DC mig will cover a lot of bases- even aluminum with the right wire gas/ and or spool gun Many can be operated on 120VAC or 240 VAC also which is great if you need portability.
The portable stick /tig that kOua posted is also hard to beat.
Lots of ways to go
