Ford 1710 Hydraulic leak
   / Ford 1710 Hydraulic leak #11
#6 on this exploded view are what leak. To much stress on these orings from the movement! Crap design!!
   / Ford 1710 Hydraulic leak #12
On another note my FEL controls was not working correctly when the valve/pump was leaking. The joystick would not return by itself. I guess it needs full pressure to work right.
   / Ford 1710 Hydraulic leak #13
Another thing make sure your engine mount bolts are tight, the movement (twisting) is what hurts orings.
I think this is where mine is leaking from too....
   / Ford 1710 Hydraulic leak #17
The problem is the stupid design, it should have some kind of flexible hose between the pump and valve. There is a kit that fixes this but its 300 plus dollars. I will just change tye orings every year.
Nolo - did you find the banjo bolt to be extremely hard to get off?
   / Ford 1710 Hydraulic leak #19
No sir, mine easily came off. If I remember right I only used a wrench, didnt even double it up. Did you get the leak fixed? Did you notice how stupid the design is?
   / Ford 1710 Hydraulic leak #20
Make sure when you get the diverter valve off to tighten motor/frame bolts that are behind the diverter.
Year: 2021 Make: Chevrolet Model: 3500/4500 Vehicle Type: Truck Mileage: Plate: Body Type: Tilt Cab (A51692)
Year: 2021 Make...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
