Ford 1710 Hydraulic leak
   / Ford 1710 Hydraulic leak #11
#6 on this exploded view are what leak. To much stress on these orings from the movement! Crap design!!
   / Ford 1710 Hydraulic leak #12
On another note my FEL controls was not working correctly when the valve/pump was leaking. The joystick would not return by itself. I guess it needs full pressure to work right.
   / Ford 1710 Hydraulic leak #13
Another thing make sure your engine mount bolts are tight, the movement (twisting) is what hurts orings.
I think this is where mine is leaking from too....
   / Ford 1710 Hydraulic leak #17
The problem is the stupid design, it should have some kind of flexible hose between the pump and valve. There is a kit that fixes this but its 300 plus dollars. I will just change tye orings every year.
Nolo - did you find the banjo bolt to be extremely hard to get off?
   / Ford 1710 Hydraulic leak #19
No sir, mine easily came off. If I remember right I only used a wrench, didnt even double it up. Did you get the leak fixed? Did you notice how stupid the design is?
   / Ford 1710 Hydraulic leak #20
Make sure when you get the diverter valve off to tighten motor/frame bolts that are behind the diverter.
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
