MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,111
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Last spring I decided to resend my lawn rather than apply crabgrass fertilizer, and it shows. My lawn now is dominated by crabgrass it seems, and plenty of clover too. Weather is starting to feel like fall so what should I do now? reseed with good grass, or apply crabgrass and clover herbicides?
As I mentioned, now is the time to mow your lawn very short, and bag the clippings. It'll also bag your grabgrass seeds. Then aerate your lawn. This opens up holes in the soil so fertilizer and grass seed can get in there. Once it's aerated, apply fertilizer but NO WEEDKILLER. You can top-dress the lawn with compost if you want, or you can just rake the plugs left from the aeration to break them up and mix in the fertilizer. Now plant your grass seed. Water it daily until you get hard frosts. Then wait until spring. In very early spring, put down your grab grass preventer. That's a preemergent that will stop any crabgrass seeds that are in the lawns (they can remain dormant for years, or spread from other areas) from germinating. You may have to put a second application of grabgrass preventer a month later, as it all depends on the timing of when your soil warms up enough for the crabgrass seeds to germinate. After that, apply regular weed and feed type fertilizer. Your best defense for crabgrass is a thick, healthy lawn, where the good grass shades out the crabgrass. This method will do that.
You're in the north, so adjust your timing to get your grass seed in at least 6 weeks before the hard freezes and ground freezes or it'll be too late. Best of luck. :thumbsup:
